I’m using nodemcu with Blynk server
Aim:
1)To read 8 different sensor values.
2) read temperature and humidity using DHT11.
3) control 4ch relay using physical push button+ Blynk application (virtual buttons).
Procedure:
1)To read 8 different sensor values, since nodemcu has only one analog input pin so I used
8-1multiplexer(4051be) that uses digital pins to switch between different sensors.
2)Read temperature and humidity with DHT11 sensor
3)Control 4 relays with 4 physical buttons and also via Blynk application include relaystate sync with virtual buttons in the Blynk application…
here i’m giving 3 programs i want to merge all these 3 programs in to single program…please help me to merge
program no (1)
[using physical 4 buttons using Nodemcu esp8266 to switch relays]
digital pin D5,D6,D7,D8,D9,D10,SD2,SD3 pins were used
D9,D10,SD2,SD3 as INPUT push buttons
D5,D6,D7,D8 as OUTPUT to 4ch relay
char auth[] = “auth”;
char ssid[] = “ssid”;
char pass[] = “password”;
// Set your LED and physical button pins here
const int ledPin1 = 12;
const int ledPin2 = 13;
const int ledPin3 = 14;
const int ledPin4 = 15;
const int btnPin1 = 3;
const int btnPin2 = 1;
const int btnPin3 = 9;
const int btnPin4 = 10;
void checkPhysicalButton();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
// Every time we connect to the cloud…
BLYNK_CONNECTED() {
Blynk.syncVirtual(V12);
Blynk.syncVirtual(V13);
Blynk.syncVirtual(V14);
Blynk.syncVirtual(V15);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V12, led1State);
//Blynk.virtualWrite(V13, led2State);
//Blynk.virtualWrite(V14, led3State);
//Blynk.virtualWrite(V15, led4State);
// When App button is pushed - switch the state
BLYNK_WRITE(V12) {
led1State = param.asInt();
digitalWrite(ledPin1, led1State);
BLYNK_WRITE(V13) {
led2State = param.asInt();
digitalWrite(ledPin2, led2State);
BLYNK_WRITE(V14) {
led3State = param.asInt();
digitalWrite(ledPin3, led3State);
BLYNK_WRITE(V15) {
led4State = param.asInt();
digitalWrite(ledPin4, led4State);
if (digitalRead(btnPin1) == LOW) {
// btn1State is used to avoid sequential toggles
if (btn1State != LOW) {
// Toggle LED state
led1State = !led1State;
// Update Button Widget
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btnPin2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
led2State = !led2State;
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btnPin3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
led3State = !led3State;
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btnPin4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
led4State = !led4State;
btn4State = LOW;
btn4State = HIGH;
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 8442);
pinMode(ledPin1, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
pinMode(ledPin2, OUTPUT);
pinMode(btnPin2, INPUT_PULLUP);
pinMode(ledPin3, OUTPUT);
pinMode(btnPin3, INPUT_PULLUP);
pinMode(ledPin4, OUTPUT);
pinMode(btnPin4, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
program no (2)
[using DHT11 sensor to collect temperature and humidity]
Digital pin 4 was used as input ***/
#include <DHT.h>
char pass[] = "YourPassword";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
program no (3)
[using 8-1 multiplexer (4051be) to reading 8_sensor values]
D1,D2,D3 & A0 pins used
D1,D2,D3 as OUTPUT
A0 as INPUT***/
char auth[] = "auth";
char ssid[] = "ssid";
char pass[] = "password";
int Sensor_1;
int Sensor_2;
int Sensor_3;
int Sensor_4;
int Sensor_5;
int Sensor_6;
int Sensor_7;
int Sensor_8;
int Pin_D5 = 5; //14 is a Gpio pin number label as D5
int Pin_D6 = 4; //12 is a Gpio pin number label as D6
int Pin_D7 = 0; //13 is a Gpio pin number label as D7
Serial.begin(9600); //Start serial monitor
pinMode(Pin_D5,OUTPUT);
pinMode(Pin_D6,OUTPUT);
pinMode(Pin_D7,OUTPUT);
pinMode(A0,INPUT);
//for Sensor_1
digitalWrite(Pin_D5, LOW); //Turn D5 Off
digitalWrite(Pin_D6, LOW); //Turn D6 Off
digitalWrite(Pin_D7, LOW); //Turn D7 Off
delay(100); //Wait for sensor
Sensor_1 = analogRead(0); //Read Analog pin as SENSOR1
//Repeat for sensor_2
digitalWrite(Pin_D7, HIGH); //Turn D7 On
Sensor_2 = analogRead(0); //Read Analog pin as SENSOR2
//Repeat for sensor_3
digitalWrite(Pin_D6, HIGH); //Turn D6 On
Sensor_3 = analogRead(0); //Read Analog pin as SENSOR3
//Repeat for sensor_4
Sensor_4 = analogRead(0); //Read Analog pin as SENSOR4
//Repeat for sensor_5
digitalWrite(Pin_D5, HIGH); //Turn D5 On
Sensor_5 = analogRead(0); //Read Analog pin as SENSOR5
//Repeat fo
Sensor_6 = analogRead(0); //Read Analog pin as SENSOR6
//Repeat for sensor_7
Sensor_7 = analogRead(0); //Read Analog pin as SENSOR7
//Repeat for sensor_8
Sensor_8 = analogRead(0); //Read Analog pin as SENSOR8
//Print the results to the serial monitor
Serial.print(" / Sensor1=");
Serial.print(Sensor_1);
Serial.print(" / Sensor2=");
Serial.print(Sensor_2);
Serial.print(" / Sensor3=");
Serial.print(Sensor_3);
Serial.print(" / Sensor4=");
Serial.print(Sensor_4);
Serial.print(" / Sensor5=");
Serial.print(Sensor_5);
Serial.print(" / Sensor6=");
Serial.print(Sensor_6);
Serial.print(" / Sensor7=");
Serial.print(Sensor_7);
Serial.print(" / Sensor8=");
Serial.print(Sensor_8);
Blynk.virtualWrite(V18, Sensor_1); //Write values to Blynk server
Blynk.virtualWrite(V19, Sensor_2); //Write values to Blynk server
Blynk.virtualWrite(V20, Sensor_3); //Write values to Blynk server
Blynk.virtualWrite(V21, Sensor_4); //Write values to Blynk server
Blynk.virtualWrite(V22, Sensor_5); //Write values to Blynk server
Blynk.virtualWrite(V23, Sensor_6); //Write values to Blynk server
Blynk.virtualWrite(V24, Sensor_7); //Write values to Blynk server
Blynk.virtualWrite(V25, Sensor_8); //Write values to Blynk server
