Hi, itās my first time here asking to the community,
So, its simple problem i guess, iāve been looking around almost for 3 days but none of the existing code iāve learned work in my sketch,
What i want to do is, create a SwitchButton on V1, When the switch turn on, the LED will turn on for 10 seconds, and then, after 10 seconds the switch automatically back to off also the LED,
Iām using ESP8266-01 GPI02 connected to my LED,
here is my existing code without timer/hold/delay function, only turn on and off
char auth[] = "invisible";
char ssid[] = "ABAH NET";
char pass[] = "DAVINAFUAD123";
int LED = 2;
BLYNK_WRITE(V1) //Button Widget is writing to pin V1
int pinData = param.asInt();
if (pinData == 1)
digitalWrite(LED, HIGH);}
digitalWrite(LED, LOW);
// to avoid delay() function!
