More information required.
Code?
Connections used?
WiFi WPA2
Please edit your post to add triple backticks before and after your code so that it displays correctly.
int pin = 21;
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = “aEbPaAkgsFwWICcd0dQ-ZSOEpAC8BLG6”;
// Set password to “” for open networks.
char ssid[] = “eduroam-2G”;
char pass[] = “*********”;
pinMode(pin, OUTPUT);
pinMode(pin, HIGH);
Serial.println(ssid);
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
delay(500);
Serial.print(".");
Serial.println(“WiFi connected”);
Blynk.begin(“Your auth token key”, ssid, pass);
void loop(){
There’s an EDIT button at the bottom of the post, and I was hoping that you would have do as I requested and actually dated it.
I’ve deleted the code from your previous post.
Done editing it
You’ve included your actual Auth token earlier, and stored it as a variable named auth
Is this what you’re using in this connection string, or something else?
I don’t see any code related to DHT11
what pins are you using to connect DHT11 data ??
#include <WiFi.h>
#include <DHT.h>
char auth[] = "8ydYe91_SqXfyPmWjiGALbQTCIXT1CKy";
char ssid[] = "eduroam-2G";
char pass[] = "******";
#define DHTPIN 0 // D15
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
//Blynk.begin(auth, ssid, pass, IPAddress(172,18,91,37), 8080);
// to avoid delay() function!
So what’s happening here?
You’ve posted two totally different pieces of code, with no explanation as to which one related to your serial monitor output.
Some words would help with people’s understanding of what it is that you’re doing.
don’t use GPIO 0 from ESP32
use from GPIO13 to 33
sorry the earliest one is for the LED…
The latest one is for the dht 11 and still the same error is happening.
The connection is taking more than 5 mins…
So which pin I should include ?
example of the code ?
The main issue here is the internet connection
I am using GPIO 13
//*********************** Initialize DHTP11 SENSOR ****************************//
//dht.begin();
dht.setup(dhtPin, DHTesp::DHT11); // Connect DHT sensor to GPIO 13
Your issue is not internet connection, but ESP32 reset due to GPIO 0
