Where do you call that void ?
Maybe you should start from the beginning.
Post your proper code, details of your board, which pins youâre using to connect your sensor, details of what youâve set-up in your app project, copy and paste your serial output and explain in words what problems youâre experiencing, what things youâve tried, and what results youâve observed.
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
char auth[] = "8ydYe91_SqXfyPmWjiGALbQTCIXT1CKy";
char ssid[] = "eduroam-2G";
char pass[] = "*******";
#define DHTPIN 13 // Connect DHT sensor to GPIO 13
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println(ssid);
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
delay(500);
Serial.print(".");
Serial.println("Setup done");
//Blynk.begin(auth, ssid, pass, IPAddress(172,18,91,37), 8080);
dht.begin();
This is my latest code and the error is such as belowâŚ
Are you sure that your ESP32 is ok ?
Guru Meditation Error: Core 0 panicâed, not Blynk related .
Try to disconnect all pin of DHT11 (VCC included ) and see what happens.
I donât think youâve understood what Iâve asked.
Iâm taking a step back from this thread.
Best of luck with resolving your issue.
