Help with Virtual Pins
As I said in an earlier post I’m a noob.
I’m using a NodeMCU with Blynk on a Android phone.
I’m setting up a virtual button and trying to also use a Virtual LED to show when the button is in a high state.
The problem I’m having is the virtual LED only gets a quarter line on the outside. I does not fill in. It’s like it’s only reading a partial state between low and high. I’m sure it’s in my coding; but I can’t find the issue. Please forgive me if I didn’t format my code right.
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#define N_DIMMERS 3
#define led_pin D0
int dimmer_pin[] = {14, 5, 15};
char auth[] = "**";
char ssid[] = "**";
char pass[] = "**";
char host[] = "ESP-OTA";
// Select your pin with physical button
const int btnPin = D2;
int btnState = LOW;
WidgetLED led3(V20);
BLYNK_CONNECTED() {
  Blynk.syncAll();
void LedWidget() {
  if  (digitalRead(btnPin) == HIGH) {  // Sets LED widget ON or OFF depending on state of btnpin
    led3.on();
    led3.off ();
void updateButtonWidgetIfNeeded() {
  int newBtnState = digitalRead(btnPin);
  if (btnState != newBtnState) {
    btnState = newBtnState;
    Blynk.virtualWrite(V20, btnState);
BLYNK_WRITE(V21) {
  digitalWrite(btnPin, param.asInt());
  updateButtonWidgetIfNeeded();
void ButtonWidget() {
    Blynk.virtualWrite(V20, HIGH);
    Blynk.virtualWrite(V20, LOW);
  pinMode(led_pin, OUTPUT);
  digitalWrite(led_pin, LOW);
  pinMode(btnPin, OUTPUT);
  timer.setInterval(1000L, updateButtonWidgetIfNeeded);
  Serial.println("Booting");
  WiFi.mode(WIFI_STA);
  // WiFi.begin(ssid, password);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
    Serial.println("Retrying connection...");
  /* switch off led */
  digitalWrite(led_pin, HIGH);
  /* configure dimmers, and OTA server events */
  analogWriteRange(1000);
  analogWrite(led_pin, 990);
  for (int i = 0; i < N_DIMMERS; i++) {
    pinMode(dimmer_pin[i], OUTPUT);
    analogWrite(dimmer_pin[i], 50);
  ArduinoOTA.setHostname(host);
  ArduinoOTA.onStart([]() { // switch off all the PWMs during upgrade
      analogWrite(dimmer_pin[i], 0);
    analogWrite(led_pin, 0);
  ArduinoOTA.onEnd([]() { // do a fancy thing with our board led at end
    for (int i = 0; i < 30; i++) {
      analogWrite(led_pin, (i * 100) % 1001);
      delay(50);
  ArduinoOTA.onError([](ota_error_t error) {
    (void)error;
    ESP.restart();
  /* setup the OTA server */
  ArduinoOTA.begin();
  Serial.println("Ready");
BLYNK_WRITE(V20) {
  digitalWrite(btnPin, param.asInt());  // Sets btnPin HIGH or LOW depending on state of Button Widget.
  ArduinoOTA.handle();
Sorry, but you still haven’t formatted your code properly for viewing on this forum… use the correct backtick keys
Blynk - FTFC
The directions on how was in the text you removed when posting this topic (fine to remove them… but please read first :stuck_out_tongue_winking_eye: )
Was also in the Welcome Topic that all new users should thoroughly read before posting…
As for your Virtual LED… just like real LEDs it can be ON, OFF or a variant in between.
When setting the value with a Blynk.virtualWrite() command you are akin to setting a PWM value with a range of 0-255. So HIGH = 1 = Low intensity (not OFF, but just barely ON… thus only the edge “lights” up).
Try this…
Blynk.virtualWrite(V20, 255);  // Full intensity
Widget LEDs also have their own distinct commands, so led3.on(); will do the same full intensity thing as the command above
And finally, when using the distinct commands… presetting the intensity with a led3.setvalue(127); (in Setup or elsewhere in code) will turn ON a vLED, but at the mid-level intensity instead of the default full intensity.
PS… more fun with Virtual LEDs using Blynk.setProperty(vPin, “property”, value)
Thank you Gunner,
Did not work. It caused the led and button to both flash rapidly.
I’ll keep working on it. I sent the sketch to a friend and it works on his iPhone.
Thanks for the help Gunner I have it solved. The vLED I was trying to light was Set the same as the button and they need to be different in the sketch and Blynk. Doh!!!
It’s a steep learning curve.
