I would like to know how to make my code work with the new blynk. Its a WOL that worked with the old Mobile Blynk app, but with the new one my protect just disappeared.
I have this set up as datastreams
this is the code, I find wright it but it worked, the “-” that I used are just to fill in the spaces with my personal info I don’t want to show,. It worked perfectly, but just today the old blynk mobila app just shut down and it stoped working.
#define BLYNK_TEMPLATE_ID "TMPLEaiejjC_"
#define BLYNK_DEVICE_NAME "SDMNAS"
//#define DEBUG
#ifdef DEBUG
//#define BLYNK_DEBUG
//#define ENABLE_DEBUG_PING
#endif
#define BLYNK_NO_BUILTIN //disable built-in analog and digital operations.
//#define BLYNK_NO_INFO //disable providing info about device to the server. (saving time)
#include <WiFiUdp.h>
#include <ESP8266Ping.h>
//blynk colors
#define BLYNK_GREEN "#23C48E"
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_YELLOW "#ED9D00"
#define BLYNK_RED "#D3435C"
#define BLYNK_DARK_BLUE "#5F7CD8"
//WiFi config
const char auth[] = "---------";
const char ssid[] = "--------";
const char pass[] = --------";
const IPAddress ip(--------);
const IPAddress gateway(--------);
const IPAddress bcastAddr(--------);
const IPAddress subnet(--------);
const IPAddress dns(--------);
//WOL device config
const IPAddress device_ip(--------);
byte macAddr[6] = {--------};
//Alert config
const char email[] = "--------";
const char device_name[] = "--------";
const uint16_t boot_time = 45; //number for countdown (It does not represent seconds, read the known issues!)
//WOL
#define MAGIC_PACKET_LENGTH 102
#define PORT_WAKEONLAN 9
byte magicPacket[MAGIC_PACKET_LENGTH];
unsigned int localPort = 9;
WiFiUDP udp;
//pins
#define STATE_PIN V0
#define BUTTON_PIN V1
#define PING_TIME_PIN V2
#define RSSI_PIN V3
//state
struct WOLServerState {
bool IsOnline;
uint16_t boot_time;
bool boot_error;
uint16_t ping;
uint32_t previousMillis;
uint32_t interval;
WOLServerState currentState = { false, 0, false, 0, 0, 5000UL };
#ifdef DEBUG
#endif
connectWiFi();
connectBlynk();
//if (Blynk.connected()) {
if (udp.begin(localPort) == 1) {
BLYNK_LOG("udp begin OK");
buildMagicPacket();
delay(500);
ESP.restart();
void connectWiFi() {
WiFi.mode(WIFI_STA);
WiFi.hostname("WOL server");
WiFi.config(ip, dns, gateway, subnet);
WiFi.begin(ssid, pass);
int count = 0;
delay(250);
digitalWrite(LED_BUILTIN, HIGH);
delay(250);
digitalWrite(LED_BUILTIN, LOW);
count++;
if (count > 20) {
delay(500);
ESP.restart();
//BLYNK_LOG("WiFi connected, IP: %s", WiFi.localIP().toString());
void connectBlynk() {
Blynk.config(auth);
Blynk.disconnect();
int count = 0;
while (Blynk.connect(10000) == false) {
delay(250);
delay(250);
count++;
if (count > 20) {
delay(500);
ESP.restart();
BLYNK_LOG("Blynk connected");
// Reconnect WiFi
if (WiFi.status() != WL_CONNECTED) {
connectWiFi();
return;
// Reconnect to Blynk Cloud
if (!Blynk.connected()) {
connectBlynk();
return;
uint32_t currentMillis = millis();
if (currentMillis - currentState.previousMillis >= currentState.interval) {
currentState.previousMillis = currentMillis;
if (currentState.boot_time == 0) {
currentState.interval = 5000UL;
currentState.boot_time--;
currentState.boot_error = true;
Blynk.email(email, "{DEVICE_NAME} : Alert", String(device_name) + " could not be turned on!");
if (Ping.ping(device_ip, 1)) {
currentState.IsOnline = true;
currentState.boot_error = false;
currentState.boot_time = 0;
currentState.ping = Ping.averageTime();
currentState.IsOnline = false;
currentState.ping = 0;
// Generate magic packet
void buildMagicPacket() {
memset(magicPacket, 0xFF, 6);
for (int i = 0; i < 16; i++) {
int ofs = i * sizeof(macAddr) + 6;
memcpy(&magicPacket[ofs], macAddr, sizeof(macAddr));
//BLYNK_CONNECTED() {
// Blynk.syncVirtual(BUTTON_PIN);
// BOOT PC button handler of application
BLYNK_WRITE(BUTTON_PIN) {
if (!currentState.IsOnline && currentState.boot_time == 0) {
BLYNK_LOG("AppButtonWakeOnLan: value=%d", param.asInt());
udp.beginPacket(bcastAddr, PORT_WAKEONLAN);
udp.write(magicPacket, MAGIC_PACKET_LENGTH);
udp.endPacket();
currentState.boot_time = boot_time;
currentState.interval = 1000UL;
BLYNK_READ(STATE_PIN) {
Blynk.virtualWrite(RSSI_PIN, WiFi.RSSI());
Blynk.virtualWrite(PING_TIME_PIN, currentState.ping);
if (currentState.IsOnline) {
Blynk.setProperty(STATE_PIN, "color", BLYNK_GREEN);
Blynk.virtualWrite(STATE_PIN, String(device_name) + " is Online");
Blynk.setProperty(BUTTON_PIN, "color", BLYNK_DARK_BLUE);
Blynk.setProperty(BUTTON_PIN, "offLabel", String(device_name) + " running...");
Blynk.setProperty(BUTTON_PIN, "onLabel", String(device_name) + " running...");
} else if (!currentState.IsOnline && currentState.boot_time > 0) {
Blynk.setProperty(STATE_PIN, "color", BLYNK_BLUE);
Blynk.virtualWrite(STATE_PIN, "Waiting for ping...");
Blynk.setProperty(BUTTON_PIN, "color", BLYNK_YELLOW);
Blynk.setProperty(BUTTON_PIN, "offLabel", currentState.boot_time);
Blynk.setProperty(BUTTON_PIN, "onLabel", "Waiting for ping...");
} else if (!currentState.IsOnline && currentState.boot_time == 0 && currentState.boot_error) {
Blynk.setProperty(STATE_PIN, "color", BLYNK_RED);
Blynk.virtualWrite(STATE_PIN, "Oops! Something happened, Try It Again!");
Blynk.setProperty(BUTTON_PIN, "offLabel", "Try It Again");
Blynk.setProperty(BUTTON_PIN, "onLabel", "Magic Packet has been sent");
Blynk.virtualWrite(STATE_PIN, String(device_name) + " is Offline");
Blynk.setProperty(BUTTON_PIN, "color", BLYNK_BLUE);
Blynk.setProperty(BUTTON_PIN, "offLabel", "Turn On");
