Hello there!
I have looked through the internet in need of an interesting project and I came across a smartwatch designed by the YouTuber Technowright. It seemed like something I can do and all of the hardware and circuitry was easy enough for me to understand, however, I completely suck at software.
The software provided with the project was good, however, it required being connected to the internet at all times. That there is no problem for me, however, I needed to integrate the wifi manager library in order to be able to actually be able to productively use this watch, allowing me to become social and leave my house without my laptop and TTL adapters. However, since this isnât originally my code and since I really am new to this style of programming I ran into some errors.
Most notably:
The compiler stops at the line
Blynk.begin(auth);
with the error
no matching function for call to 'BlynkWifi::begin(char [33])'
I have noticed a similar forum post but I didnât understand how it would relate to my specific example.
Also please let me know if there is something else that I completely screwed up while trying to integrate wifi manager that hasnât yet surfaced.
Thanks for taking a look!
Full code:
// ESP8266_SmartWatch.ino
// Written by Shyam Ravi, the Technowright -> this isn't me, if I could've written this code, I woud've been able to probably fix this issue.
// Visit my Youtube channel at https://www.youtube.com/thetechnowright
// Libraries needed:
// Time.h & TimeLib.h: https://github.com/PaulStoffregen/Time
// Timezone.h: https://github.com/JChristensen/Timezone
// SSD1306.h & SSD1306Wire.h: https://github.com/squix78/esp8266-oled-ssd1306
// NTPClient.h: https://github.com/arduino-libraries/NTPClient
// ESP8266WiFi.h & WifiUDP.h: https://github.com/ekstrand/ESP8266wifi
// Download latest Blynk library here: https://github.com/blynkkk/blynk-library/releases/latest
// 128x64 OLED pinout:
// GND goes to ground
// Vin goes to 3.3V
// Data to I2C SDA (GPIO 4)
// Clk to I2C SCL (GPIO 5)
#include <WifiUDP.h>
#include <String.h>
#include <Wire.h>
#include <SSD1306.h>
#include <SSD1306Wire.h>
#include <NTPClient.h>
#include <Time.h>
#include <TimeLib.h>
#include <Timezone.h>
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h>
const int DataDisplayButton = 14;
int RelayButtonPin1 = 12;
int RelayButtonPin2 = 13;
int Relay1Pin = 2; //Relay pin on the other ESP8266
int Relay2Pin = 0; //Relay pin on the other ESP8266
int Relay1State = HIGH; // the current state of the output pin
int Relay2State = HIGH; // the current state of the output pin
String RlSt = String(Relay1State, HEX);
int Relay1ButtonState; // the current reading from the input pin
int Relay2ButtonState; // the current reading from the input pin
int lastButtonState1 = LOW; // the previous reading from the input pin
int lastButtonState2 = LOW; // the previous reading from the input pin
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime1 = 0; // the last time the output pin was toggled
unsigned long lastDebounceTime2 = 0; // the last time the output pin was toggled
unsigned long debounceDelay1 = 50; // the debounce time; increase if the output flickers
unsigned long debounceDelay2 = 50; // the debounce time; increase if the output flickers
char auth[] = "254a18667df8466c985b4938476eXXXX"; //Enter your Authentication Token
// Define NTP properties
#define NTP_OFFSET 60 * 60 // In seconds
#define NTP_INTERVAL 60 * 1000 // In miliseconds
#define NTP_ADDRESS "pool.ntp.org" // change this to whatever pool is closest (see ntp.org)
// Set up the NTP UDP client
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, NTP_ADDRESS, NTP_OFFSET, NTP_INTERVAL);
// Create a display object
SSD1306 display(0x3C, 4, 5); //0x3d for the Adafruit 1.3" OLED, 0x3C being the usual address of the OLED
String date;
String t;
String tempC;
const char * days[] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"} ;
const char * months[] = {"Jan", "Feb", "Mar", "Apr", "May", "June", "July", "Aug", "Sep", "Oct", "Nov", "Dec"} ;
const char * ampm[] = {"AM", "PM"} ;
const char hostname[] = "weather-ydn-yql.media.yahoo.com";
const String url = "/forecastrss?w=2442047&u=f"; //put the link to Yahoo Weather API here woeid 12761354
const int port = 80;
unsigned long timeout = 10000; //ms
WiFiClient client;
WidgetBridge bridge1(V1); // Connect the Relay module
BLYNK_CONNECTED() {
// Place the AuthToken of the second hardware here
bridge1.setAuthToken("6c5494cacbde42cc9bc58ccd68eXXXX"); // Enter the Auth token of the relay module(Other Esp8266 Module);
void setup ()
Serial.begin(115200); // most ESP-01's use 115200 but this could vary
timeClient.begin(); // Start the NTP UDP client
Wire.pins(4, 5); // Start the OLED with GPIO 4 and 5 on ESP-01
Wire.begin(4, 5); // 4=sda, 5=scl
display.init();
display.flipScreenVertically();
WiFiManager wifiManager;
wifiManager.autoConnect("IOT Watch Connection Setup Tool (esp8266)", " XXXX) ");
Blynk.begin(auth);
// Connect to wifi
pinMode(DataDisplayButton, INPUT);
Serial.println("");
display.drawString(0, 0, "Connected to WiFi.");
Serial.print(WiFi.localIP());
Serial.println("");
display.drawString(0, 24, "Hi Blynk Forums, thanks for helping!");
display.display();
int buttonState = digitalRead(DataDisplayButton);
if (buttonState == LOW) {
Serial.print("Button pressed");
GetWeatherData();
tellTime();
delay(6000);
else {
display.clear();
ControlRelays();
display.display();
void ControlRelays(){
// read the state of the switch into a local variable:
int reading1 = digitalRead(RelayButtonPin1);
int reading2 = digitalRead(RelayButtonPin2);
if(reading1 == LOW || reading2 == LOW){ // Tell the state of the Lights
display.drawRect(0, 20, 60, 40);
display.drawRect(61, 20, 60, 40);
display.setFont(ArialMT_Plain_10);
display.drawString(17, 3, "Lights");
display.drawString(84, 3, "A/C");
if(Relay1State == HIGH){
display.setFont(ArialMT_Plain_16);
display.drawString(18, 30, "ON");
else if(Relay1State == LOW){
display.drawString(15, 30, "OFF");
if(Relay2State == HIGH){
display.drawString(78, 30, "ON");
else if(Relay2State == LOW){
display.drawString(76, 30, "OFF");
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited long enough
// since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading1 != lastButtonState1) {
// reset the debouncing timer
lastDebounceTime1 = millis();
if (reading2 != lastButtonState2) {
lastDebounceTime2 = millis();
if ((millis() - lastDebounceTime1) > debounceDelay1) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading1 != Relay1ButtonState) {
Relay1ButtonState = reading1;
// only toggle the LED if the new button state is HIGH
if (Relay1ButtonState == HIGH) {
Relay1State = !Relay1State;
if ((millis() - lastDebounceTime2) > debounceDelay2) {
if (reading2 != Relay2ButtonState) {
Relay2ButtonState = reading2;
if (Relay2ButtonState == HIGH) {
Relay2State = !Relay2State;
// set the LED:
bridge1.digitalWrite(Relay1Pin, Relay1State);
bridge1.digitalWrite(Relay2Pin, Relay2State);
// save the reading. Next time through the loop, it'll be the lastButtonState:
lastButtonState1 = reading1;
lastButtonState2 = reading2;
void tellTime() {
if (WiFi.status() == WL_CONNECTED) //Check WiFi connection status
date = ""; // clear the variables
t = "";
// update the NTP client and get the UNIX UTC timestamp
timeClient.update();
unsigned long epochTime = timeClient.getEpochTime();
// convert received time stamp to time_t object
time_t local, utc;
utc = epochTime;
// Then convert the UTC UNIX timestamp to local time
TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2, +150}; //UTC - 5 hours - change this as needed
TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, +150}; //UTC - 6 hours - change this as needed
Timezone usEastern(usEDT, usEST);
local = usEastern.toLocal(utc);
// now format the Time variables into strings with proper names for month, day etc
date += days[weekday(local) - 1];
date += ", ";
date += months[month(local) - 1];
date += " ";
date += day(local);
date += ", ";
date += year(local);
// format the time to 12-hour format with AM/PM and no seconds
t += hourFormat12(local);
t += ":";
if (minute(local) < 10) // add a zero if minute is under 10
t += "0";
t += minute(local);
t += " ";
t += ampm[isPM(local)];
// Display the date and time
Serial.println("");
Serial.print("Local date: ");
Serial.print(date);
Serial.println("");
Serial.print("Local time: ");
Serial.print(t);
// print the date and time on the OLED
display.clear();
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_24);
display.drawStringMaxWidth(64, 14, 128, t); // print time on the display
display.drawStringMaxWidth(64, 42, 128, date); // print date on the display
display.drawString(70, 0, "Temp:"); // prints the Temperature from GetWeatherData() function
display.drawString(100, 0, tempC); // Replace with "temp" to get temperaute in Farenheit
display.drawString(113, 0, "C");
display.display();
else // attempt to connect to wifi again if disconnected
display.clear();
display.drawString(0, 18, "Disconnected. Reconnecting to Wifi.");
display.display();
wifiManager.autoConnect("IOT Watch Connection Setup Tool (esp8266)", "XXX");
display.drawString(0, 32, "Connected.");
display.display();
void GetWeatherData(){
unsigned long timestamp;
int temp;
// Establish TCP connection
Serial.println(hostname);
if ( !client.connect(hostname, port) ) {
Serial.println("Connection failed");
// Send GET request
String req = "GET " + url + " HTTP/1.1\r\n" +
"Host: " + hostname + "\r\n" +
"Connection: close\r\n" +
"\r\n";
"Authorization: OAuth"
"oauth_consumer_key="dj0yJmk9SjVpN2FnVzBsVlVoJnM9Y29uc3VtZXJzZWNyZXQmc3XXX",oauth_signature_method="HMAC-SHA1",oauth_timestamp="YOUR_TIMESTAMP",oauth_nonce="YOUR_NONCE",oauth_version="1.0",oauth_signature="YOUR_GENERATED_SIGNATURE"" //awaiting these from yahoo
"cache-control: no-cache"
client.print(req);
// Wait for response from server
delay(500);
timestamp = millis();
while ( !client.available() && (millis() < timestamp + timeout) ) {
delay(1);
// Parse temperature
if ( client.find("temp\":") ) {
temp = client.parseInt();
tempC = (temp - 32) * 5/9 ;
Serial.print("Local temperature: ");
Serial.print(tempC);
Serial.println("°C");
// Flush receive buffer
while ( client.available() ) {
client.readStringUntil('\r');
// Close TCP connection
client.stop();
Serial.println();
Serial.println("Connection closed");
- Marton Baksa
