Your sketch doesnāt have any # include <> statements for the Blynk libraries, so its impossible for it to compile as it stands.
Youāre also using SimpleTimer instead of BlynkTimer, but you donāt have a # include <> statement for that library eitherā¦
This line doesnāt belong in this sketchā¦
and this wonāt work with Blynk IoT because itās a Legacy commandā¦
Even if it did work, or you replaced it with the IoT equivalent (logEvent) then youād send the same notification once every second while data > 500 and quickly hit the allowed limit for events.
Read this for more info on how to do notifications in Blynk IoT and how to use āflagā variables to avoid unwanted repeat notificationsā¦
i have corrected the code and it is able to compile but still cannot connect to blynk and the serial monitor is also blank . thank you
#include<WiFiClient.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "lRoRyr52ZZomiPLKEPaCoiha1MHDVpI6"
/* WiFi credentials */
char ssid[] = "anjing";
char pass[] = "bajingan";
char server[] = "blynk-cloud.com";
int port = 8080;
char auth[] = "lRoRyr52ZZomiPLKEPaCoiha1MHDVpI6";
int mq135 = A0; // smoke sensor is connected with the analog pin A0
int data = 0;
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
timer.setInterval(1000L, getSendData); // new data will be updated every 1 sec
* Send Sensor data to Blynk
void getSendData()
data = analogRead(mq135);
Blynk.virtualWrite(V4, data); //
this is the code that is updated t. it is able to connect with blynk but the problem is data is not be able to send to my template
#include <WiFi.h>
char server[] = "blynk.cloud";
int port = 8080;
int mq135 = 34; // smoke sensor is connected with the analog pin A0
int analog_data=analogRead(mq135);
void sendSensor()
Blynk.virtualWrite(V4,analog_data);
delay(300);
timer.setInterval(1000L, sendSensor); // new data will be updated every 1 sec
Serial.println(analog_data);
delay(200);
