Haha
I have to write your code and test it
can you try to change V2 push mode to switch mode in the phone App ?
Haha
i did try both, currently its in switch mode. No luck!
Ok I’m writing your code to see where is the bug
That works for me :
void checkPhysicalButton()
if (digitalRead(P1) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
digitalWrite(ledPin, ledState);
// Update Button Widget
if(ledState==0){
Blynk.virtualWrite(V2 , LOW);
}else{
Blynk.virtualWrite(V2 , HIGH);
btnState = LOW;
btnState = HIGH;
okay flashing it, and i want to show you this.
in phone app it works on GPIO ( digital ) GP0,
Not virtual.
getting this error now…
error: ‘P1’ was not declared in this scope; did you mean ‘y1’?
98 | if (digitalRead(P1) == LOW) {
| y1
exit status 1
Yes replace P1 by btnPin
But V2 can’t work because you have select digitalPin instead of virtualPin
Thats why im telling you…it is working on digitalpin…nothing works if i select V2
Maybe you should look at your previous post…
yeah i have seen it but it was posted before fixing the button sync issue.
You can’t control V2 if it isn’t a virtual button
Still no luck its not working…
we need to look somewhere else… look at the url it is working with D0 “”“oT5y/update/D0?value=0"”" not with V2.
God!!!
Maybe the Sketch Builder “Sync Physical button” example is where you should start,
@ [Blynk_Coeur]
Man it started to pick on V2 but the problem is " button states changes for a mili sec and goes back to off
The problem is here …
I think you have to start from scratch ![]()
EEEEEEHAAA!!! WE SOLVED IT MAN
i removed the line
Blynk.virtualWrite(V2, millis() / 1000); // Send UpTime seconds to App
Its working now…tell me how do i buy you a coffee ?
why shhhhh ?
let others taste the fruit of our tree.
Ok I just saw that
Comon DM me, i really need to say thanks to you.
Because you made my smart farmhouse project completed because i need lots of these.
