I have this code running fine, button when i toggle relay using physical button it does not update the state in blynk app, i got it working before somehow but i don’t remember.
Any help will be appreciated.
Pull/Push works on D0 rather than V0 or V1.
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "Vito's Vifi";
char pass[] = "xxxxxxxxxxxxxx";
char server[] = "blynk-cloud.com"; // URL for Blynk Cloud Server
int port = 8080;
int DeviceLED = 2;
int ReCnctFlag; // Reconnection Flag
int ReCnctCount = 0; // Reconnection counter
// Set your LED and physical button pins here
const int ledPin = 0;
const int btnPin = 2;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
pinMode(ledPin, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
digitalWrite(ledPin, ledState);
WiFi.begin(ssid, pass); // Non-blocking if no WiFi available
Blynk.config(auth, server, port);
Blynk.connect();
timer.setInterval(1000L, UpTime);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Serial.println("Cconnected");
ReCnctCount = 0;
Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState = param.asInt();
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
// Update Button Widget
Blynk.virtualWrite(V2 , ledState);
btnState = LOW;
btnState = HIGH;
void UpTime() {
Blynk.virtualWrite(V2, millis() / 1000); // Send UpTime seconds to App
Serial.print("UpTime: ");
Serial.println(millis() / 1000); // Send UpTime seconds to Serial
digitalWrite(DeviceLED, !digitalRead(DeviceLED)); // Blink onboard LED
if (Blynk.connected()) { // If connected run as normal
} else if (ReCnctFlag == 0) { // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
ReCnctFlag = 1; // Set reconnection Flag
Serial.println("Starting reconnection timer in 30 seconds...");
timer.setTimeout(30000L, []() { // Lambda Reconnection Timer Function
ReCnctFlag = 0; // Reset reconnection Flag
ReCnctCount++; // Increment reconnection Counter
Serial.print("Attempting reconnection #");
Serial.println(ReCnctCount);
Blynk.connect(); // Try to reconnect to the server
}); // END Timer Function
