Need help with this code (run the code if there is no internet or wifi)
i am making a project of standalone ESP8266 with single channel relay with a synced physical button. the code works fine. i just want to run the code if there is no internet or wifi is off.
The code does not run without Internet.
here is my code
char auth[] = "88decc9cb88340c9a5bead06423469d3";
char ssid[] = "Tesla";
char pass[] = "3015854308";
// Set your LED and physical button pins here
const int ledPin = 0;
const int btnPin = 2;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V2);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
  ledState = param.asInt();
  digitalWrite(ledPin, ledState);
  if (digitalRead(btnPin) == LOW) {
    if (btnState != LOW) {
      // Toggle LED state
      ledState = !ledState;
      // Update Button Widget
    btnState = LOW;
    btnState = HIGH;
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT_PULLUP);
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
use Blynk.config and Blynk.connect instead Blynk.begin
I have successfully did it, Thank you so much for your help, wish i could buy you a cup of coffee :slight_smile: . This code works like a charm on stand alone esp8266 with single channel relay with sync button state and also physcial button connected to gpio 2 + GND (push button). Whether wifi is off or there is no internet it works and when internet comes back it reconnects to blynk server. i hope this code will help many many people. Thanks a bunch. here is picture of my prototype project, i am going to build more for my smart home.
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to synchronize Button widget
  and physical button state.
  App project setup:
    Button widget attached to V2 (Switch mode)
char auth[] = "xxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxx";
char server[] = "blynk-cloud.com";  // URL for Blynk Cloud Server
int port = 8080;
int DeviceLED = 2;
int ReCnctFlag;  // Reconnection Flag
int ReCnctCount = 0;  // Reconnection counter
int ledState = LOW;
  WiFi.begin(ssid, pass);  // Non-blocking if no WiFi available
  Blynk.config(auth, server, port);
  Blynk.connect();
  timer.setInterval(1000L, UpTime);
BLYNK_CONNECTED() {
  Serial.println("Cconnected");
  ReCnctCount = 0;
BLYNK_WRITE(V2) {
      // Toggle LED state
    btnState = LOW;
    btnState = HIGH;
void UpTime() {
  Blynk.virtualWrite(V0, millis() / 1000);  // Send UpTime seconds to App
  Serial.print("UpTime: ");
  Serial.println(millis() / 1000);  // Send UpTime seconds to Serial
  digitalWrite(DeviceLED, !digitalRead(DeviceLED));  // Blink onboard LED
  if (Blynk.connected()) {  // If connected run as normal
  } else if (ReCnctFlag == 0) {  // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
    ReCnctFlag = 1;  // Set reconnection Flag
    Serial.println("Starting reconnection timer in 30 seconds...");
    timer.setTimeout(30000L, []() {  // Lambda Reconnection Timer Function
      ReCnctFlag = 0;  // Reset reconnection Flag
      ReCnctCount++;  // Increment reconnection Counter
      Serial.print("Attempting reconnection #");
      Serial.println(ReCnctCount);
      Blynk.connect();  // Try to reconnect to the server
    });  // END Timer Function
I tried using the code above for an arduino MKR wifi-1010 but it doesn’t work properly. After losing the internet connection, the code runs normal for a few seconds with the physical buttons and then it doesn’t work anymore.
Then the physical buttons only work again when the internet returns again.
Then it locks for a minute and returns to normal operation.
Can someone help me?
Here is the code:
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <IoAbstraction.h>
#include <IoAbstractionWire.h>
#include <Wire.h>
// create both an Arduino and an IO expander based IO abstraction
IoAbstractionRef ioExpander = ioFrom8574(0x20);
IoAbstractionRef ioExpander1 = ioFrom8574(0x21);
IoAbstractionRef ioExpander2 = ioFrom8574(0x22);
IoAbstractionRef ioExpander3 = ioFrom8574(0x23);
char auth[] = "XXXXXXX";
char ssid[] = "XXXXX";
char pass[] = "XXXX";
int port = 8080;
const int ledPin = 6;
const int btnPin = 7;
int ledState = LOW;  int btnState = HIGH;
int ledState2 = LOW; int btnState2 = HIGH;
int ledState3 = LOW; int btnState3 = HIGH;
int blackout = 0;
 // Blynk.begin(auth, ssid, pass);
  Blynk.connect();
  Wire.begin();
  timer.setInterval(100L, checkPhysicalButton); // Setup a function to be called every 100 ms
  // here we set the direction of pins on the IO expander
  ioDevicePinMode(ioExpander, 0, INPUT);
  ioDevicePinMode(ioExpander, 1, INPUT);
  ioDevicePinMode(ioExpander, 2, INPUT);
  ioDevicePinMode(ioExpander, 3, INPUT);
  ioDevicePinMode(ioExpander, 4, OUTPUT);
  ioDevicePinMode(ioExpander, 5, OUTPUT);
  ioDevicePinMode(ioExpander, 6, OUTPUT);
  ioDevicePinMode(ioExpander, 7, OUTPUT);
  BLYNK_CONNECTED() {
  ReCnctCount = 0;
  Blynk.syncVirtual(V2); // Request the latest state from the server
  Blynk.syncVirtual(V3); // Request the latest state from the server
  Blynk.syncVirtual(V4); // Request the latest state from the server
  //Blynk.virtualWrite(V2, ledState); // Alternatively, you could override server state using:
BLYNK_WRITE(V2) {ledState = param.asInt(); digitalWrite(ledPin, ledState);}
BLYNK_WRITE(V3) {ledState2 = param.asInt(); ioDeviceDigitalWrite(ioExpander, 4, ledState2);}
BLYNK_WRITE(V4) {ledState3 = param.asInt(); ioDeviceDigitalWrite(ioExpander, 5, ledState3);}
ioDeviceSync(ioExpander);
    if (btnState != LOW) {ledState = !ledState;
    Blynk.virtualWrite(V2, ledState); }
    btnState = LOW;} else {btnState = HIGH; }
    if (ioDeviceDigitalRead(ioExpander, 0) == LOW) {
    if (btnState2 != LOW) {ledState2 = !ledState2;
    Blynk.virtualWrite(V3, ledState2);
    btnState2 = LOW;} else {btnState2 = HIGH;}
    if (ioDeviceDigitalRead(ioExpander, 1) == LOW) {
    if (btnState3 != LOW) {ledState3 = !ledState3;
    Blynk.virtualWrite(V4, ledState3);
    btnState3 = LOW;} else {btnState3 = HIGH;}
   timer.run();  //timer2.run();
Could you provide us serial monitor screenshot when connection is down?
When showing the messages below that the arduino is stuck, the buttons do not work.
Attempting reconnection # 1
[124900] Connecting to blynk-cloud.com:8080
Attempting reconnection # 2
[182649] Connecting to blynk-cloud.com:8080
It only works when the message below appears:
Starting reconnection timer in 30 seconds…
So are you saying that the buttons so work for the 30 seconds between re-connection attempts?
If so, that’s different to what you said here:
Sorry if I wasn’t clear.
I will explain the steps:
The internet goes down:
The buttons work until the message appears on the serial monitor:
When the message appears:
the buttons work again and stay in this cycle until the internet connection is reestablished.
Take a look at my new code…it works flawlessly.
So, maybe the solution is that you do one or more of the following…
  1. reduce the re-connection attempts from 2 to 1
  2. increase the timeout timer delay so that its longer
  3. specify a timeout for Blynk.connect by using Blynk.connect(xx)
When blynk is trying to connect to the server, code is blocked a few seconds.
There is now available solution to avoid that.
The only way to passthrough is to use ESP32.
I think @khoih may also have an alternative solution.
If the switch operation is so critical for you that you can’t wait in max (yet configurable) 30s, the best way to do is to use ISR (directly or via Hardware Timer Interrupt).
There are so many discussions in the forum about this issue, you can just do some searching and will find them.
For example:
But using ISR correctly is not a simple task, you have to spend some time to study and use it correctly or the percentage of crashing is 100%.
Why do I only use esp32 to avoid this problem? I am using MKR wifi 1010 and it is as powerful as esp32.
I wonder if there is any other solution without having to migrate to esp32
Thanks for the answer, but I don’t think it would be useful to control all the buttons on my home automation.
Because ESP32 is a two cores, but not MRK !
So, with ESP32 you can run Blynk.run on one core, no worry if it’s hanging , the other core, continue to run.
Else, use the alternative ISR solution as @khoih suggested you.
If you have a serious home automation system then I think you’re using the wrong topology if you’re running Blynk on each device.
Life gets much easier when you have one gateway which talks to Blynk, and then multiple devices which talk to that gateway - using MQTT messaging.
Yes, you still need to deal with situations where the devices cant connect to the MQTT server and you want them to operate in stand-alone ,mode, but this scenario happens less often that an internet outage, and the re-connection routines can be much more seamless.
This approach makes integration with other services, such as Amazon Alexa Zigbee, cloud services etc much simpler. It also makes Blynk simply an app interface, rater than the core functionality within the system. This makes it easier to either swap to a different app front-end, or have multiple user interface systems such as Nextion touch screens - which give you almost unlimited user interface design options.
Thanks for the advice, I’m doing the integration with Jarvis iot and blynk.
But I will research further on using other ways to create a 100% flawless system.
I think at the moment the solution for me is to install the local blynk server on a raspberry so that there is no problem when I lose the internet, the code does not block. And to use remotely I will try to use the Blynk API to update the app.
What do you think of this?
