hello everyone i am new to blynk and i am trying to use it to monitor and control Ph of water … so i working with esp32 and i was trying to add this code from DFRobot_ESP_PH_BY_GREENPONIK
but this code is using serial monitor in arduino app to enter commands to set the ph calibration as the following
* file DFRobot_ESP_PH.cpp * @ https://github.com/GreenPonik/DFRobot_ESP_PH_BY_GREENPONIK
* Arduino library for Gravity: Analog pH Sensor / Meter Kit V2, SKU: SEN0161-V2
* ########## Fork on github by GreenPonik ##########
* ############# ONLY ESP COMPATIBLE ################
* version V1.0
* date 2019-05
#include "Arduino.h"
#include "DFRobot_ESP_PH.h"
#include "EEPROM.h"
#define PH_3_VOLTAGE 2010
DFRobot_ESP_PH::DFRobot_ESP_PH()
this->_temperature = 25.0;
this->_phValue = 7.0;
this->_acidVoltage = 2032.44; //buffer solution 4.0 at 25C
this->_neutralVoltage = 1500.0; //buffer solution 7.0 at 25C
this->_voltage = 1500.0;
DFRobot_ESP_PH::~DFRobot_ESP_PH()
void DFRobot_ESP_PH::begin()
//check if calibration values (neutral and acid) are stored in eeprom
this->_neutralVoltage = EEPROM.readFloat(PHVALUEADDR); //load the neutral (pH = 7.0)voltage of the pH board from the EEPROM
if (this->_neutralVoltage == float() || isnan(this->_neutralVoltage))
this->_neutralVoltage = 1500.0; // new EEPROM, write typical voltage
EEPROM.writeFloat(PHVALUEADDR, this->_neutralVoltage);
EEPROM.commit();
this->_acidVoltage = EEPROM.readFloat(PHVALUEADDR + sizeof(float)); //load the acid (pH = 4.0) voltage of the pH board from the EEPROM
if (this->_acidVoltage == float() || isnan(this->_acidVoltage))
this->_acidVoltage = 2032.44; // new EEPROM, write typical voltage
EEPROM.writeFloat(PHVALUEADDR + sizeof(float), this->_acidVoltage);
EEPROM.commit();
float DFRobot_ESP_PH::readPH(float voltage, float temperature)
// Serial.print("_neutraVoltage:");
// Serial.print(this->_neutralVoltage);
// Serial.print(", _acidVoltage:");
// Serial.print(this->_acidVoltage);
float slope = (7.0 - 4.0) / ((this->_neutralVoltage - 1500.0) / 3.0 - (this->_acidVoltage - 1500.0) / 3.0); // two point: (_neutralVoltage,7.0),(_acidVoltage,4.0)
float intercept = 7.0 - slope * (this->_neutralVoltage - 1500.0) / 3.0;
// Serial.print(", slope:");
// Serial.print(slope);
// Serial.print(", intercept:");
// Serial.println(intercept);
this->_phValue = slope * (voltage - 1500.0) / 3.0 + intercept; //y = k*x + b
Serial.print("[readPH]... phValue ");
Serial.println(this->_phValue);
return this->_phValue;
terminal.print("[readPH]... phValue"); // gendiaaa add
terminal.println( this->_phValue); //
void DFRobot_ESP_PH::calibration(float voltage, float temperature, char *cmd)
this->_voltage = voltage;
this->_temperature = temperature;
strupr(cmd);
phCalibration(cmdParse(cmd)); // if received Serial CMD from the serial monitor, enter into the calibration mode
void DFRobot_ESP_PH::calibration(float voltage, float temperature)
if (cmdSerialDataAvailable() > 0)
phCalibration(cmdParse()); // if received Serial CMD from the serial monitor, enter into the calibration mode
boolean DFRobot_ESP_PH::cmdSerialDataAvailable() /////////kjuhggfd
char cmdReceivedChar;
static unsigned long cmdReceivedTimeOut = millis();
while (Serial.available() > 0)
if (millis() - cmdReceivedTimeOut > 500U)
this->_cmdReceivedBufferIndex = 0;
memset(this->_cmdReceivedBuffer, 0, (ReceivedBufferLength));
cmdReceivedChar = Serial.read();
if (cmdReceivedChar == '\n' || this->_cmdReceivedBufferIndex == ReceivedBufferLength - 1)
strupr(this->_cmdReceivedBuffer);
return true;
this->_cmdReceivedBuffer[this->_cmdReceivedBufferIndex] = cmdReceivedChar;
this->_cmdReceivedBufferIndex++;
// gendiaaa Add
while (terminal.available() > 0)
cmdReceivedChar = terminal.read();
return true;
// gendiaaa Add
return false;
byte DFRobot_ESP_PH::cmdParse(const char *cmd)
byte modeIndex = 0;
if (strstr(cmd, "ENTERPH") != NULL)
modeIndex = 1;
else if (strstr(cmd, "EXITPH") != NULL)
modeIndex = 3;
else if (strstr(cmd, "CALPH") != NULL)
modeIndex = 2;
return modeIndex;
byte DFRobot_ESP_PH::cmdParse()
byte modeIndex = 0;
if (strstr(this->_cmdReceivedBuffer, "ENTERPH") != NULL)
modeIndex = 1;
else if (strstr(this->_cmdReceivedBuffer, "EXITPH") != NULL)
modeIndex = 3;
else if (strstr(this->_cmdReceivedBuffer, "CALPH") != NULL)
modeIndex = 2;
return modeIndex;
void DFRobot_ESP_PH::phCalibration(byte mode)
char *receivedBufferPtr;
static boolean phCalibrationFinish = 0;
static boolean enterCalibrationFlag = 0;
switch (mode)
case 0:
if (enterCalibrationFlag)
Serial.println(F(">>>Command Error<<<"));
terminal.println(">>>Command Error<<<"); // gendiaaa add
break;
case 1:
enterCalibrationFlag = 1;
Serial.println();
Serial.println(F(">>>Enter PH Calibration Mode<<<"));
Serial.println(F(">>>Please put the probe into the 4.0 or 7.0 standard buffer solution<<<"));
Serial.println();
terminal.println(">>>Enter PH Calibration Mode<<<"); // gendiaaa add
terminal.println(">>>Please put the probe into the 4.0 or 7.0 standard buffer solution<<<");
break;
case 2:
if ((this->_voltage > PH_8_VOLTAGE) && (this->_voltage < PH_6_VOLTAGE))
{ // buffer solution:7.0
Serial.println();
Serial.print(F(">>>Buffer Solution:7.0"));
terminal.print(">>>Buffer Solution:7.0\""); // gendiaaa add
this->_neutralVoltage = this->_voltage;
Serial.println(F(",Send EXITPH to Save and Exit<<<"));
Serial.println();
terminal.print(",Send EXITPH to Save and Exit<<<\""); // gendiaaa add
phCalibrationFinish = 1;
else if ((this->_voltage > PH_5_VOLTAGE) && (this->_voltage < PH_3_VOLTAGE))
{ //buffer solution:4.0
Serial.println();
Serial.print(F(">>>Buffer Solution:4.0"));
terminal.print(">>>Buffer Solution:4.0\""); // gendiaaa add
this->_acidVoltage = this->_voltage;
Serial.println();
Serial.println();
Serial.print(F(">>>Buffer Solution Error Try Again<<<"));
Serial.println(); // not buffer solution or faulty operation
terminal.print(">>>Buffer Solution Error Try Again<<<\""); // gendiaaa add
break;
case 3: //store calibration value in eeprom
Serial.println();
if (phCalibrationFinish)
if ((this->_voltage > PH_8_VOLTAGE) && (this->_voltage < PH_5_VOLTAGE))
EEPROM.commit();
EEPROM.commit();
Serial.print(F(">>>Calibration Successful"));
terminal.print(">>>Calibration Successful\""); // gendiaaa add
Serial.print(F(">>>Calibration Failed"));
terminal.print(">>>Calibration Failed\""); // gendiaaa add
Serial.println(F(",Exit PH Calibration Mode<<<"));
Serial.println();
terminal.print(",Exit PH Calibration Mode<<<\""); // gendiaaa add
break;
as you see i am trying to add terminal.print but its not decleared ! whatever in the main source
i included the blynk as shown here
#ifdef ESP8266
#elif defined(ESP32)
#include <BlynkSimpleEsp32.h>
#else
#error "Board not found"
#endif
credentials Credentials;
#include "EEPROM.h"
WidgetTerminal terminal(V1);
DFRobot_ESP_PH ph;
#define ESPADC 4096.0 //the esp Analog Digital Convertion value
#define ESPVOLTAGE 3300 //the esp voltage supply value
#define PH_PIN 36 //the esp gpio data pin number
float voltage, phValue, temperature = 25;
//Variables
char auth_token[33];
bool connected_to_internet = 0;
const int Erasing_button = 15;
//Provide credentials for your ESP server
char* esp_ssid = "EgyReef";
char* esp_pass = "";
pinMode(Erasing_button, INPUT);
for (uint8_t t = 4; t > 0; t--) {
Serial.println(t);
// Press and hold the button to erase all the credentials
if (digitalRead(Erasing_button) == LOW)
Credentials.Erase_eeprom();
String auth_string = Credentials.EEPROM_Config();
auth_string.toCharArray(auth_token, 33);
if (Credentials.credentials_get())
Blynk.config(auth_token);
connected_to_internet = 1;
Credentials.setupAP(esp_ssid, esp_pass);
if (connected_to_internet)
//SETUP FOR MY PH CODE
EEPROM.begin(32);//needed to permit storage of calibration value in eeprom
ph.begin();
//END SETUP FOR PH
Credentials.server_loops();
//LOOP CODE FOR PH
static unsigned long timepoint = millis();
if (millis() - timepoint > 1000U) //time interval: 1s
//voltage = rawPinValue / esp32ADC * esp32Vin
voltage = analogRead(PH_PIN) / ESPADC * ESPVOLTAGE; // read the voltage
Serial.print("voltage:");
Serial.println(voltage, 4);
//temperature = readTemperature(); // read your temperature sensor to execute temperature compensation
Serial.print("temperature:");
Serial.print(temperature, 1);
Serial.println("^C");
phValue = ph.readPH(voltage, temperature); // convert voltage to pH with temperature compensation
Serial.print("pH:");
Serial.println(phValue, 4);
Blynk.virtualWrite(V3, phValue);
ph.calibration(voltage, temperature); // calibration process by Serail CMD
//END LOOP FOR PH
i can write here now i wish i can write by blink code well
its very useful and easy to understand i will try to implement that in the code
