HC-SR04 Ultrasonic Sensor Does Not Write To Serial
I have an project where i can turn on off my Coffe Maker from the app that is time based. That part works fine. But when i try to add an Ultrasonic Sensor to the code, i can’t get any reading to the serial.
Sometimes it shows only the distance one time, but nothing after that.
All works regards to the ultrasonic sensor when i remove all other code. So my question is why i can’t get any readings from my sensor from the Serial monitor with the attatched code under?
//Put WiFi cridentials and token here----------------------------------
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define echoPin D6 // Echo Pin
#define trigPin D5 // Trigger Pin
long duration, distance; // Duration used to calculate distance
int coffeeSwitch = 13;
int yellowLED = 4;
int greenLED = 5;
int coffeeTimer;
  pinMode(coffeeSwitch, OUTPUT);
  digitalWrite(coffeeSwitch, HIGH);
  pinMode(yellowLED, OUTPUT);
  pinMode(greenLED, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  timer.setInterval(2000L, waterLevel);
void waterLevel(){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
Serial.println(distance);
//Delay 50ms before next reading.
delay(50);
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V1);
void LEDtimer() {
  digitalWrite(greenLED, LOW);
void coffeeOFF() {
  Blynk.virtualWrite(V1, LOW);
  digitalWrite(yellowLED, LOW);
  digitalWrite(greenLED, HIGH);
  Blynk.notify("Kaffen er klar!");
  timer.setTimeout(120000L, LEDtimer);
BLYNK_WRITE(V1) {
  int pinValue = param.asInt();
  if (pinValue == 1)   {
    digitalWrite(coffeeSwitch, LOW);
    digitalWrite(yellowLED, HIGH);
    coffeeTimer =  timer.setTimeout(720000L, coffeeOFF);
  if (pinValue == 0) {
    timer.deleteTimer(coffeeTimer);
Just for clarifying. The ultrasonic Sensor i want ti use for measure water level in Coffe Maker water tank. I’m using Wemos D1 Mini (ESP8266).
…haven’t used it with blynk, but two things:
  • the standard SR04 model is for 5V, so a voltage devider is needed for the GPIO on the wemos, connected to the echo pin.
  • can’t tell if your code is driving it correctly. I’d use / try to incorporate the new-ping lib from here: https://bitbucket.org/teckel12/arduino-new-ping/wiki/Home
I tried the library you linked to and that works fine also, if i not include my own code.
So the first code works, but not the bottom code:
#include <NewPing.h>
#define TRIGGER_PIN  D5  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     D6  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(1000);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
Do not work:
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
int yellowLED = 4;
int greenLED = 5;
int coffeeTimer;
  timer.setInterval(1000L, waterLevel);
void waterLevel(){
BLYNK_CONNECTED() {
void LEDtimer(){
void coffeeOFF() {
BLYNK_WRITE(V1) {
Does your serial monitor print “Ping” at all?
Try removing all but the water height function. Do not even enable Serial.begin. Instead of printing value, put a display widget in your app, assign the read to a variable and do a Blynk virtualWrite if that variable to the display widget.
float distanceWater = 0.0;
void waterLevel(){
  distanceWater = (sonar.ping_cm());
  Blynk.virtualWrite(V4,distanceWater);
Yes, the last code work. It writes to the app widget and to Serial mnitor when i enable it. But not when i add my own code.
There’s the path to your solution . . . Start with the working code, then slowly add one line (or one function) at a time, and check results.
When the code fails you should have narrowed it down to a small section, rather that “all my code”
cul
billd
Yes, i know that. I just wonder if there was an obvious error in my code. But since it isn’t, i’m going to try that metod :slight_smile:
i ´ve got a problem with my Blynk app
I use ESP32 and ESP8266 board.
In app I use Level V Settings with HC-SR04.
I havent had a problem yet
But since last week it didnt work.
I Think it might be a problem in reading rate.
My scatch is still the same And I havent changed anything.
I wonder if you might change something there.
I see the values in my serial monitor But i Really couldnt see it in the app.
Thank your for checking
Daniel
See this topic…
