hello all,
i’m used nodemcu esp 8266 and LED light . i connected LED to D7.
my problem, The NodeMCU is not connecting to my wifi router and show for my hard resetting via RTS pin
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "zviMJ7vZ8oC1yyHFjzQh_Zsapq6Nv1MV";
char ssid[] = "HUAWEI-E5330-5CE8";
char pass[] = "eg871rr4";
Executable segment sizes:
IROM : 247340 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27736 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1308 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 3068 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25560 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 279452 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 29936 bytes (36%) of dynamic memory, leaving 51984 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM7
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: bc:dd:c2:30:a3:4b
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 283600 bytes to 205209...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (15 %)
Writing at 0x00008000... (23 %)
Writing at 0x0000c000... (30 %)
Writing at 0x00010000... (38 %)
Writing at 0x00014000... (46 %)
Writing at 0x00018000... (53 %)
Writing at 0x0001c000... (61 %)
Writing at 0x00020000... (69 %)
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 283600 bytes (205209 compressed) at 0x00000000 in 18.5 seconds (effective 122.4 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
