I am a new Blynk user. I am using an AdaFruit Huzzah ESP32 module with Arduino
I got the quickstart template and device example to work.
I grabbed the Send Email code example from your code generation widget, copied it into a new sketch, changed the credentials: Template ID, Device Name and Auth Token to match a new template and new device I created. It compiles and I send the firmware to my board.
There is no email sent when my board connects even though I see the Ready Message like I see with the Quickstart device.
And the example has an interrupt feature that is supposed to send an email when a button is pushed.
I push the button for the pin I assigned (not the default digital pin 2) and then I get the Guru Meditation Error:
11:26:49.055 -> [3834] Ready (ping: 16ms).
11:26:49.126 -> Email should be sent here!
11:26:54.175 -> Button is pressed.
11:26:54.492 -> Guru Meditation Error: Core 1 panic'ed (Unknown reason).
11:26:54.492 ->
11:26:54.492 -> Core 1 register dump:
11:26:54.492 -> PC : 0x4008e2d2 PS : 0x00060235 A0 : 0x8008d26e A1 : 0x3ffbe99c
11:26:54.492 -> A2 : 0x3ffcd10c A3 : 0x3ffb8890 A4 : 0x00000004 A5 : 0x00060223
11:26:54.492 -> A6 : 0x00060223 A7 : 0x00000001 A8 : 0x3ffb8890 A9 : 0x00000018
11:26:54.529 -> A10 : 0x3ffb8890 A11 : 0x00000018 A12 : 0x00000000 A13 : 0x00000000
11:26:54.529 -> A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000000
11:26:54.529 -> EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
11:26:54.529 ->
11:26:54.529 ->
11:26:54.529 -> Backtrace:0x4008e2cf:0x3ffbe99c |<-CORRUPTED
11:26:54.529 ->
11:26:54.529 ->
11:26:54.529 -> Core 0 register dump:
11:26:54.529 -> PC : 0x4008e453 PS : 0x00060035 A0 : 0x8008ce97 A1 : 0x8008c5f1
11:26:54.567 -> A2 : 0x3ffbe9bc A3 : 0x3ffcd10c A4 : 0xffffffff A5 : 0x00060023
11:26:54.567 -> A6 : 0x00060021 A7 : 0x0000cdcd A8 : 0x0000abab A9 : 0x800f9b09
11:26:54.567 -> A10 : 0x3ffbe9dc A11 : 0x00000000 A12 : 0x3ffcd134 A13 : 0x3ffbf0e8
11:26:54.567 -> A14 : 0x00000000 A15 : 0x00000001 SAR : 0x00000000 EXCCAUSE: 0x00000006
11:26:54.567 -> EXCVADDR: 0x00000000 LBEG : 0x3ffc341c LEND : 0xcb36abd5 LCOUNT : 0x00000000
11:26:54.601 ->
11:26:54.601 ->
11:26:54.601 -> Backtrace:0x4008e450:0x8008c5f1 |<-CORRUPTED
11:26:54.601 ->
11:26:54.601 ->
11:26:54.601 ->
11:26:54.601 ->
11:26:54.601 -> ELF file SHA256: 0000000000000000
11:26:54.601 ->
11:26:54.601 -> Rebooting...
Any ideas? I did not use Edgent_ESP32 code to initialize the board with the mobile app first.
This the boilerplate code I am using:
Simple e-mail example
App project setup:
E-mail Widget
Connect a button to digital pin 2 and GND
Pressing this button will send an e-mail
WARNING: You are limited to send ONLY ONE E-MAIL PER 5 SECONDS!
#define BLYNK_TEMPLATE_ID "redacted"
#define BLYNK_DEVICE_NAME "redacted"
#define BLYNK_AUTH_TOKEN "redacted"
/* Set this to a bigger number, to enable sending longer messages */
//#define BLYNK_MAX_SENDBYTES 128
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
unsigned count = 0;
void emailOnButtonPress()
// *** WARNING: You are limited to send ONLY ONE E-MAIL PER 5 SECONDS! ***
// Let's send an e-mail when you press the button
// connected to digital pin 2 on your Arduino
int isButtonPressed = !digitalRead(2); // Invert state, since button is "Active LOW"
if (isButtonPressed) // You can write any condition to trigger e-mail sending
Serial.println("Button is pressed."); // This can be seen in the Serial Monitor
count++;
String body = String("You pushed the button ") + count + " times.";
Blynk.email("your_email@mail.com", "Subject: Button Logger", body);
// Or, if you want to use the email specified in the App (like for App Export):
//Blynk.email("Subject: Button Logger", "You just pushed the button...");
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// Send e-mail when your hardware gets connected to Blynk Server
// Just put the recepient's "e-mail address", "Subject" and the "message body"
Blynk.email("your_email@mail.com", "Subject", "My Blynk project is online.");
// Setting the button
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(2), emailOnButtonPress, CHANGE);
