Google assistant + IFTTT
How did you configure vpin 0 datastream ?
Yes Sir
V0
Maaz
Show me the datastream please
Put 1 instead of 100 in the url
Ok sir
I will try
Dear sir
Still cannot
Maaz
Are you sure you’re using the right token ?
Dear sir
Yes sir I sure I am using the correct token
Best Regards
Maaz
Try digital pin datastream
Ok sir
I will try that also before
I try again sir
Best regards
Maaz
Dear sir
Still cannot
Maaz
Not like this
Dear sir
if you have any screen shot please send me thank you
Best Regards
Maaz
Does your relay operate correctly if you add a switch widget to the app or desktop console that is connected to V0 ?
Does the API call work if you paste it into the address bar of your browser?
What code are you running on your device, and how is your relay connected to your device?
Also, you should learn to use the Windows sniping tools rather than posting pictures of your monitor.
When you create a new datastream there’s digital option.
But it’s not yet supported (as far as I know).
I know it’s not supported in the automation but in the api I’m not sure.
Dear sir
tnanks for reply
yes sir i am using mobile app it will work
when i am using browser showing 1 but relay not triger
Maaz
Can you trigger the relay using the app ?
