GET/PUT command to write data in Virtual Pins
Hello blynkers.
I need to write a value in a virtual pin using GET or any method. However, using the examples from the Blynk Documentation, I could not reach the goal.
http://blynk-cloud.com/auth_token/update/pin?value=value. With this sentence, I need to fix a value.
There is some way to set a value from a variable? For example:
http://blynk-cloud.com/auth_token/update/pin?value=temperatureA
Hey there,
Are you using blynk IOT or legacy ?
The API expects a string as the value.
If you explain more about how, and why, you are using the API then we may be able to assist.
For example, is this a data write from IFTTT, or a similar service, or from another device?
If the API call is being made from a different physical location then you may need to take precautions to avoid Geo DNS issues.
Hello John,
I’m using the Legacy (old version).
I can exchange information between arduinos , alexas and nodered. However, for this setpoint, I can use only fixed values.
Just to explain better, I want to say to Alexa to set a Setpoint to my temperature. So Alexa set a variable called SETPOINT.
With the value in Setpoint, I want to write on pin V17 that is my virtual pin.
Hello PeteKnight, thanks for helping.
I’m doing a project where I’m getting a setpoint for temperature from Alexa.
Up to now, I’m getting the value from Alexa and I could write to a variable called Setpoint in node red.
When I debug the program, I can see the value , however, now I need to write this value to V17 in the BlynkCloud. And this is where I stopped.
Are you using Node-RED with blynk plugin ?
Using Node-red with HTTP request…
Do we have a pallet for Blynk?
Yes, as @John93 says, it’s much easier if you use the Blynk ws contrib (for Levacy) or the Blynk IoT contrib for B,Hank IoT.
You might find this useful…
Everything working fine !!! Thanks a lot.
Pete, thanks a lot, now things are working.
