Im from Poland and when i ping fra1 is 100%lost but when i ping sgp1 or lon1 its perfectly fine.
Same problem.
fra1 canât access with mobile app
I still donât have access.
When I try with mobile data enabled I can see all my devices offline when I switch to WiFi nothing. Is there a problem with my IP address? I have static IP.
Thats server problem not yours
Fra1 is online for me
Hello. What âping 46.101.217.214â shows? Do you have web or mobile issue? Seems like same as Blynk server seems to be down in my area. But I see not issues on our side. Traffic is the same, server is healthy. So I assume thatâs some local/region/provider trouble.
ping fra1.blynk.cloud = timed out
ping 46.101.217.214 = timed out
Im from Poland and i cant connect to mobile app and i cant even login to blynk website
ping 46.101.217.214 timed out. Lost =4
The same, canât connect from mobile and to blynk website
But when I use VPN I can access both.
Same results from my area too. Iâm located at Athens Greece and there is no reply when I try to ping either the DNS name (which successfully translated to 46.101.217.214) or the directly the IP address.
Tried the ping from 2 different internet providers.
Any solution how to proceed???
No problem from France
Envoi dâune requĂȘte âpingâ sur fra1.blynk.cloud [46.101.217.214] avec 32 octets de donnĂ©es :
Réponse de 46.101.217.214 : octets=32 temps=42 ms TTL=53
Réponse de 46.101.217.214 : octets=32 temps=40 ms TTL=53
Ok now it works for some reason
