Hello, I’m getting this failed to read from DHT sensor. I already checked the pin as D3 is V0 and I also tried D4 which is V2. I’m using NodeMCU. I already refer the similar problem but most of them are the wiring problems. I also already referred to the Dht datasheet to make sure im pining the correct pin (GND> - and 3.3V > Vcc also D3> S)
#include <DHT.h>
char auth[] = "URHaTHZ_E1ufJj4Qc_vT4K8aumNlXCdF"; //Enter the Auth code which was send by Blink
char ssid[] = "Bilik Gerakan"; //Enter your WIFI Name
char pass[] = "smkbg@123"; //Enter your WIFI Password
#define DHTPIN 0 // D3
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
dht.begin();
