Paste the sketch that you used.
#include <Blynk.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
//Setup connection of the sensor
Adafruit_BME280 bme; // I2C
char auth[] = "3efa4091d9fc4ff89e2a43fe454a58ca";
char ssid[] = "BTHub6-P38S";
char pass[] = "wAwhd7rKg3cT";
float pressure; //To store the barometric pressure (Pa)
float temperature; //To store the temperature (oC)
int humidity; //To store the humidity (%) (you can also use it as a float variable)
//Wire.begin(int sda, int scl)
Wire.begin(2, 15);
bme.begin(); //Begin the sensor
Serial.begin(9600); //Begin serial communication at 9600bps
Serial.println("Adafruit BME280 test:");
timer.setInterval(2000L, ReadSensors); // read sensor every 2s
void ReadSensors(){
//Read values from the sensor:
pressure = bme.readPressure();
temperature = bme.readTemperature();
humidity = bme.readHumidity ();
Blynk.virtualWrite(V1, pressure/100); // write pressure to V1 value display widget
Blynk.virtualWrite(V2, temperature); // write temperature to V2 value display widget
Blynk.virtualWrite(V3, humidity); // write altimeter to V3 value display widget
//Print values to serial monitor:
Serial.print(F("Pressure: "));
Serial.print(pressure);
Serial.print(" Mb");
Serial.print("\t");
Serial.print(("Temp: "));
Serial.print(temperature);
Serial.print(" °C");
Serial.print("\t");
Serial.print("Humidity: ");
Serial.print(humidity); // this should be adjusted to your local forcase
Serial.println(" %");
//delay(2000); //Update every 2 sec
The BME280 i2c test sketch not the Blynk sketch.
Oooops …
BME280 I2C Test.ino
This code shows how to record data from the BME280 environmental sensor
using I2C interface. This file is an example file, part of the Arduino
BME280 library.
GNU General Public License
Written: Dec 30 2015.
Last Updated: Oct 07 2017.
Connecting the BME280 Sensor:
Sensor -> Board
Vin (Voltage In) -> 3.3V
Gnd (Ground) -> Gnd
SDA (Serial Data) -> A4 on Uno/Pro-Mini, 20 on Mega2560/Due, 2 Leonardo/Pro-Micro
SCK (Serial Clock) -> A5 on Uno/Pro-Mini, 21 on Mega2560/Due, 3 Leonardo/Pro-Micro
#include <BME280I2C.h>
#include <Wire.h>
#define SERIAL_BAUD 115200
BME280I2C bme; // Default : forced mode, standby time = 1000 ms
// Oversampling = pressure ×1, temperature ×1, humidity ×1, filter off,
Serial.begin(SERIAL_BAUD);
while(!Serial) {} // Wait
Wire.begin(2, 15);
while(!bme.begin())
Serial.println("Could not find BME280 sensor!");
switch(bme.chipModel())
case BME280::ChipModel_BME280:
Serial.println("Found BME280 sensor! Success.");
break;
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
break;
default:
Serial.println("Found UNKNOWN sensor! Error!");
printBME280Data(&Serial);
delay(500);
void printBME280Data
Stream* client
float temp(NAN), hum(NAN), pres(NAN);
BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
BME280::PresUnit presUnit(BME280::PresUnit_Pa);
bme.read(pres, temp, hum, tempUnit, presUnit);
client->print("Temp: ");
client->print(temp);
client->print("°"+ String(tempUnit == BME280::TempUnit_Celsius ? 'C' :'F'));
client->print("\t\tHumidity: ");
client->print(hum);
client->print("% RH");
client->print("\t\tPressure: ");
client->print(pres);
client->println("Pa");
Take the working sketch and just add the Blynk parts to it. Use Blynk Timer to call printBME280Data(&Serial) and comment this line out of loop().
Seeing that short sentence you wrote made me think, “yeh, I can do that”. Until I read it, not a clue have I got. ![]()
Give me a few minutes.
Presumably you are using ESP8285 in the IDE?
Yes. ?
This compiles OK for ESP8285.
It’s only got Serial Monitor output at the moment. Let me know if it works. You can add the Blynk widgets later.
/* BME280ESP8285.ino for https://community.blynk.cc/t/esp8285-i2c-pins/21458
BME280 library.
Sensor -> Board
Gnd (Ground) -> Gnd
#include <Wire.h>
Wire.begin(2, 15);
while(!bme.begin())
break;
break;
default:
timer.setInterval(3000L, readSensor); // every 3s
void readSensor(){
Stream* client
client->print(hum);
//delay(1000);
@Costas Ok, again I thought this bit sounded easy so I did what I thought needed to be done. So why is the data in the Blynk app on my phone on 1 second and off the next?
Good.
Add the following before //delay(1000);
Blynk.virtualWrite(V1, pres/100.0); // write pressure to V1 value display widget
Blynk.virtualWrite(V2, temp); // write temperature to V2 value display widget
Blynk.virtualWrite(V3, hum); // write humidity to V3 value display widget
Do you have the widgets set as PUSH frequency?
Yes,
Does Serial Monitor show a Blynk reconnect when your phone shows a problem?
Hang on, there’s two delay(1000); put it before both of them?
There is only one //delay(1000) the other is delay(1000)
The one at the very bottom. ![]()
Tried them in a few places, stil on 1 second and off the next?
Is the float function responsible for this bit?
