ESP8266 (Wemos D1 mini) can´t connect to Server
my ESP8266 can´t connect to the Cloud Server since Wednsday, what can I do?
Is the Port correct? 443? What is the right one? I´am in Germany.
12:43:08.244 → [225704] NTP time: Fri Mar 19 11:43:07 2021
12:43:08.297 → [225705] Connecting to blynk-cloud.com:443
That for helping me :slight_smile:
There were some issues with SSL connections to the Blynk cloud servers because of expired certificates, but I thought this had been fixed as discussed here…
Does a non-SSL connection work for you?
Hi, Pete
what does non-SSL connection means?
How can i test that?
I tried now
13:05:53.376 → [571] Connected to WiFi
13:05:53.376 → [572] IP: 192.168.178.121
13:05:53.423 → [572]
13:05:53.423 → ___ __ __
13:05:53.477 → / _ )/ /_ _____ / /__
13:05:53.477 → / _ / / // / _ / '/
13:05:53.524 → /
//_, /////_
13:05:53.577 → /
__/ v0.6.1 on ESP8266
13:05:53.577 →
13:05:53.577 → [661] NTP time: Fri Mar 19 12:05:53 2021
13:05:53.624 → [691] Connecting to blynk-cloud.com:1883
13:05:58.490 → [5661] NTP time: Fri Mar 19 12:05:58 2021
13:05:58.490 → [5661] Connecting to blynk-cloud.com:1883
Presumably, your sketch currently has a line near the top which says…
#include <BlynkSimpleEsp8266_SSL.h>
Replace this with…
If your Blynk.begin or Blynk.config commands have port 443 specified then change this to port 8080
Hi Pete,
it is works now. Thank but what was the Problem?
//#include <BlynkSimpleEsp8266_SSL.h>
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 8080);
13:13:28.578 → [4444] Connected to WiFi
13:13:28.578 → [4445] IP: 192.168.178.121
13:13:28.625 → [4445]
13:13:28.625 → ___ __ __
13:13:28.625 → / _ )/ /_ _____ / /__
13:13:28.678 → / _ / / // / _ / '/
13:13:28.725 → /
//_, /////_
13:13:28.725 → /
13:13:28.779 →
13:13:28.779 → [4524] Connecting to blynk-cloud.com:80
13:13:28.825 → [4599] Ready (ping: 14ms).
It seems like there is still a problem with certificates.
@Dmytro are you aware of this?
Thank you @PeterKnight for pushing on this.
