Hi, I am new to Blynk. I would like to use the Blynk App on the iPhone to send a pulse (Mimic a button press) to one of the ESP8266 GPIO to control a device. Do you know if Blynk supports pulse instead of just ON or OFF? Can you give some instructions on how it can be done? Thanks a lot.
Blynk Switch widgets can be set to Push (momentary) or Switch (on/off) mode.
In Push mode the digital GPIO Pin will be active as long as the button is held pressed. In Switch mode, one press activates it, then another press deactivates it.
If you need a pulse of a specific duration then you could attach the switch widget to a virtual pin and then use code to control your GPIO pin.
Personally, I always use virtual rather than digital pins in Blynk as they give much more control, but they do require some coding knowledge.
Here is the working code with GPIO pulse for 3secs.
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
char auth[] = "xxxxxxx";
char ssid[] = "xxxxxxx
char pass[] = "xxxxxxxx";
// Select your pin with physical button
const int away = 5;
const int indoor = 0;
const int disarm = 14;
const int alarmstatus = 12; // gpio 12 --- D6
int previoustate = 0;
WidgetLCD lcd(V10);
void PrintStatus_LCD(){
pinMode(alarmstatus,INPUT);
if (digitalRead(alarmstatus) == 1)
if (previoustate == 0)
lcd.clear();
lcd.print(0,1, " A L A R M O N");
previoustate = 1;
if (previoustate == 1)
lcd.clear();
lcd.print(0,1, "A L A R M O F F");
previoustate = 0;
// Blynk.virtualWrite(V10,digitalRead(alarmstatus));
BLYNK_WRITE(V0){
if(param.asInt()){
digitalWrite(away, HIGH);
delay(3000);
digitalWrite(away, LOW);
else{
BLYNK_WRITE(V1){
if(param.asInt()){
digitalWrite(indoor, HIGH);
delay(3000);
digitalWrite(indoor, LOW);
else{
BLYNK_WRITE(V2){
if(param.asInt()){
digitalWrite(disarm, HIGH);
delay(3000);
digitalWrite(disarm, LOW);
else{
pinMode(away, OUTPUT);
pinMode(indoor, OUTPUT );
pinMode(disarm, OUTPUT);
timer.setInterval(1000L, PrintStatus_LCD);
Firstly, you need to edit your post (using the pencil icon at the bottom of the post) and format the code correctly, so that it displays correctly:
Second,my using delay(3000); is very bad practice in Blynk. Whilst you might get away with it sometimes, you’ll almost certainly suffer disconnections if you use it regularly.
What you should do is to trigger a countdown timer of duration 3000 instead.
Take a look at this thread:
Thanks for the tip Pete!
I think your term “pulse” (in MCU terms typically a rapid, possibly repeating, ON/OFF signal) in your title and topic is misleading… you seem to be simply requiring a press for a time, no pulsing required. Perhaps some editing so as to attract the proper readership and suggestions.
I have also recently added in a code routine to make any Button Widget (or perhaps any action widget, or function call) into a timed action. Should be a simple drop in replacement for those awful delay() routines ![]()
Cool, that’s what I am looking for, thanks!
