This is an ESP 8266 based project that uses NFC reader PN532 to secure and open doors.
the code here is not current. Please use the code at github!!
Here is the github link
now tested with 4 scanners and multiple cards. also added OTA for updates and wifi / BLYNK provisioning.
The code has two blynk tokens
one for the lock and one for the master/scanner these are default values.
I implemented it as a multi door system with a maximum of 500 cards per door. It could easily be upgraded to more cards per door.
The project is now in 7 files
main file
Creative Commons License
NFC Door lock
by Michael Dale Burton
is licensed under a Creative Commons Attribution-NonCommercial
4.0 International License.
Impliments a door lock system using NFC reader and the Blynk app
Blynk is used to store the data on the cloud and provide
a smart phone interface for adding, removing and assigning cards
Device selector is used to choose the lock/door
500 cards are supported
unlimited locks are supported
1 master is used as the scanner for adding cards it can also be used as a lock
Nodemcu esp8266 and PN532 hardware is used
V1 is a timer
V2 is a reset button
V3 ia a text input for the user name assigned to a card
V4 is a value display for the card id
V5 current card index "vcount"
V6 is a terminal window for debug information
V10 is the delete button
V24 is a value display for the number of valid cards
V25 - V26 are reserved for data bridge
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h>
#include <NfcAdapter.h>
#include <ArduinoOTA.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <TimeLib.h>
#include <WidgetRTC.h>
#include "globals.h" // tab for other defines and globals
PN532_I2C pn532i2c(Wire);
PN532 nfc(pn532i2c);
//create terminal widget instance and attach it to the pin
WidgetTerminal terminal(terminaldisplay);
//Create the real time clock instance
WidgetRTC rtc;
//create timer instance
//create bridge instance and assign pins
WidgetBridge bridge1(51);
WidgetBridge bridge2(52);
WidgetBridge bridge3(53);
// get the time and the day
void getCurrentTime() {
currentTime = String(hour() + ":" + minute());
currentDate = String(day());
void lockDoor() {
digitalWrite(LED_PIN, LOW); // turn off LED this causes the door to lock
Blynk.virtualWrite(lockbutton, 0); // display door locked on the app
flag = 0;
void unlockDoor() {
if (!flag) {
flag = 1;
digitalWrite(LED_PIN, HIGH); // send power to unlock the door
timer.setTimeout(5000L, lockDoor); // lock the door after 5 seconds
Blynk.virtualWrite(lockbutton, 1); // update the app
connect to wifi
connect to blynk server
create timer
start nfc
start I2c
set I2c rate and pins
start serial and set speed
pinMode(LED_PIN, OUTPUT);
pinMode(RTS_PIN, OUTPUT);
pinMode(DTR_PIN, OUTPUT);
Wire.setClock(wirespeed); // set the Ic2 buss speed
Serial.begin(serialspeed); // open the serial port
Wire.pins(SDA_PIN, SLC_PIN); // SDA, SLC pins
Wire.begin(); // start the Ic2 buss
nfc.begin(); // init the NFC Hardware
SPIFFS.begin();
Serial.print(currentTime);
// these two call get the data from the SPIFFS file and use the data to provision blynk and wifi
restoreparameters();
startmywifi();
Blynk.config(blynk_token); // config Blynk
getdatafromfile();
// Blynk.syncVirtual(vcount, datapins); // restore count and card data This is how all the card data gets restored from the cloud
// Blynk.syncVirtual(vcount); // restore count
timer.setInterval(500l, scanNfc); // scan the NFC every .5 seconds
ArduinoOTA.setHostname(modulename); // give an name to our module
ArduinoOTA.begin(); // OTA initialization
timer.setInterval(1200L, [] () { // <<=== set how often the code should run 1200L = Run every 1.2 seconds
ArduinoOTA.handle(); // check for OTA update
}); // END Timer Function
main loop
if (Blynk.connected()){
} else Blynk.connect(1000l); // timeout 1 second
The Blynk Calls are in file 2.
#include <FS.h>
NFC Door lock
20 cards are supported
2 slaved locks are supported
V1 is a timer
V25 - V45 are reserved for data storage
#include <Wire.h>
#include <PN532.h>
WidgetRTC rtc;
void lockDoor() {
flag = 0;
void unlockDoor() {
if (!flag) {
flag = 1;
connect to wifi
create timer
start nfc
start I2c
SPIFFS.begin();
startmywifi();
getdatafromfile();
main loop
The data is handled in the third file.
NFC Door lock
Auther Michael Burton
NFC Door lock
compairUid return bool
in: card ids
out: true if they are the same else false
bool compairUid(uint8_t uid1[], uint8_t uid2[], uint8_t j) {
for (int i = 0; i < j; i++) {
if (uid1[i] != uid2[i]) {
return false;
return true;
findUid
takes uid and length
return index of uid in array or 0 if not found
int findUid(String suid) {
for (int i = 1; i <= rowIndex; i++) {
if (!(suid.compareTo(String(&cardId[i][0])))) {
return i; // index of card found
return 0;
storeCard
in: row index, card Id, id length, card holder name
places the uid and the name in the hardware memory at index location ri
out: none
//put card id in memory
void storeCard(int ri, String suid2, String holder, int af) {
if(openspiffs()){
uint16_t buffer_offset;
buffer_offset = ri * recordlength;
cardId[ri] = suid2; // save uid as a string
cardHolder[ri] = holder; // save name of card holder
accessFlags[ri] = af;
Blynk.virtualWrite(vcount, rowIndex); //save the card count on the server
write16data(0, rowIndex); //save the card count at offset 0
// Blynk.virtualWrite(DATASTORE + ri, ri, cardHolder[ri], cardId[ri], accessFlags[ri]); //save card data on server
write16data(buffer_offset, ri);
buffer_offset += 2;
writestringdata(buffer_offset, maxnamelength, cardHolder[ri]);
buffer_offset += maxnamelength;
writestringdata(buffer_offset, maxuidlength, cardId[ri]);
buffer_offset += maxuidlength;
write16data(buffer_offset, accessFlags[ri]);
buffer_offset += 2;
Blynk.virtualWrite(indexdisplay, ri);
closespiffs();
void getCard(int index) {
cardId[0] = cardId[index]; //get cardId
cardHolder[0] = cardHolder[index]; // get name of card holder
get card id access flags and user name from the cloud
in: card Id, card holder name, access flags, index
datastore is the virtual pin for the card data
void readFromCloud(int count) {
getdatafromfile();
// getdatafromfram();
// for (int i = 0; i < count; i++) {
// Blynk.syncVirtual(DATASTORE + count); //send the sync to the data pin to request card data
getCard(1);
Blynk.virtualWrite(namedisplay, cardHolder[0]);
Blynk.virtualWrite(cardiddisplay, cardId[0]);
file four is the data handling
NFC Door lock
NFC Door lock
//#define BLYNK_PRINT Serial // Comment this line out to disable prints and save space
//#define BLYNK_DEBUG
// only uncoment one at a time
//#define MASTER_LOCK true
#define LOCK1_LOCK true
//#define LOCK2_LOCK true
hardware defines
#define wirespeed 400000L // Ic2 buss speed
#define serialspeed 115200 // serial port speed
#define nfcretries 0x0f // number of passive retries before timeout on nfc hardware
PIN MAP for ESP8266
#define DATASTART 0x0 // start address of data buffer
#define IC2_FRAM_ADDRESS 0x50 // address of the fram board
#define SDA_PIN 2 // I2C SDA pin
#define SLC_PIN 14 // I2C SCL pin
#define RTS_PIN 4 // RTS line for C17A - DB9 pin 7
#define DTR_PIN 5 // DTR line for C17A - DB9 pin 4
#define RELAY_PIN 8 // relay output pin
#define LED_PIN 16 // attached LED
BLYNK V PIN MAP
#define clockpin V1
#define resetallpin V2
#define namedisplay V3
#define cardiddisplay V4
#define indexdisplay V5
#define terminaldisplay V6
#define copybutton V11
#define copyallbutton V12
#define bridgewrite V7
#define lockbutton V8
#define bridgedata V9
#define deletebutton V10
#define eventorpin V14
#define vcount V24
#define DATASTORE V25
#define datapins V25, V26, V27, V28, V29, V30, V31, V32, V33, V34, V35, V36, V37, V38, V39, V40, V41, V42, V43, V44, V45
#define maxcards 20
#define maxnamelength 20
#define maxuidlength 15
#define flagslength 1
#define recordlength (4 + maxnamelength + maxuidlength) // 4 bytes for the two ints + the max string lengths for the name and uid
const char* daystrings[7] = {"Sun", "Mon", "Tues", "Wed", "Thurs", "Fri", "Sat"};
/* BLYNK tokens
char reader_token[] = "blynk token1";
char lock1_token[] = "blynk token2";
char lock2_token[] = "blynk token 3";
char readername[] = "nfclockreader";
char lock1name[] = "nfclock1";
char lock2name[] = "nfclock2";
#if defined(MASTER_LOCK)
char blynk_token[34] = "blynk token1";
char modulename[] = "nfclockreader";
#elif defined(LOCK1_LOCK)
char blynk_token[34] = "blynk token2";
char modulename[] = "nfclock1";
#else
char blynk_token[34] = "blynk token 3";
char modulename[] = "nfclock2";
#endif
WiFi credentials.
char ssid[] = "ssid";
char pass[] = "password";
Global data
String cardId[maxcards + 1];
String cardHolder[maxcards + 1];
int accessFlags[maxcards + 1];
String SThour;
String STmin;
String SPhour;
String SPmin;
int days[7];
int flag = 0;
int cardIndex = 0;
int rowIndex = 0;
String currentTime;
String currentDate;
int talktome = 0;
//define your default values here, if there are different values in config.json, they are overwritten.
char mqtt_server[40];
char mqtt_port[6] = "8080";
//flag for saving wifi data
bool shouldSaveConfig = true;
uint32_t versiondata = 0; // NFC hardware version
String carddatafile = "/carddata.txt";
File datafile;
Card reader file
// setupnfc does not block or wait for a success
// you will need to call it again if the global var versiondata is not set
// once it sees the hardware it sets the number of retries and configures the board
// it then prints the current time and "nfc started to the terminal
void setupnfc() {
Serial.println("looking for NFC");
//search for the NFC hardware
versiondata = nfc.getFirmwareVersion();
if (versiondata){
nfc.setPassiveActivationRetries(nfcretries); // Set the max number of retry attempts to read from a card
nfc.SAMConfig(); // configure board to read RFID tags
terminal.println("NFC started");
terminal.print(currentTime);
scanNfc
Get card data from NFC hardware
void scanNfc() {
uint8_t uid[maxuidlength] = {0, 0, 0, 0, 0, 0, 0, 0}; // Buffer to store the returned UID
String suid;
uint8_t uidLength = 0; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
char holder[maxnamelength];
if (versiondata) {
nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
if (uidLength) { // found a card
for (int i = 0; i < uidLength; i++) {
suid += String(uid[i], HEX); // convert the uid to a hex string
Blynk.virtualWrite(cardiddisplay, suid); // display the uid
cardIndex = findUid(suid);
if (cardIndex) {
unlockDoor(); // unlock the door if the card was valid
Blynk.virtualWrite(namedisplay, cardHolder[cardIndex]); //display the card holder name on the app
terminal.print(cardHolder[cardIndex]); // send debug data to the terminal
terminal.print(" ");
terminal.println(currentDate);
terminal.println(cardId[cardIndex]);
terminal.flush();
Blynk.virtualWrite(indexdisplay, cardIndex); // display the card index on the app
return; // card found exit
storeCard(0, suid, String(" "), 0); // no card found clear card display
Blynk.virtualWrite(namedisplay, " "); // clear name display on the app
Blynk.virtualWrite(indexdisplay, 0); // set index display to 0 on the app
setupnfc(); // if hardware not found then start it now.
SPIFFS file
bool openspiffs(){
datafile = SPIFFS.open(carddatafile, "r+b"); // exsisting file opened
if (!datafile){
datafile = SPIFFS.open(carddatafile, "w+b"); // create new file
return datafile;
void closespiffs(){
if (datafile){
datafile.close();
void writestringdata(uint16_t whatbyte, int howlong, String databuffer){
byte s[maxnamelength+1];
datafile.seek(DATASTART+whatbyte, SeekSet);
databuffer.getBytes(s, howlong);
datafile.write(s, howlong);
datafile.flush();
String readstringdata(uint16_t whatbyte, int howlong){
char s[maxnamelength+1];
byte s2[maxnamelength+1];
datafile.read(s2, howlong);
for ( int i = 0; i < howlong; i++)
s[i] = char(s2[i]);
s[howlong] = 0;
return String(s);
uint16_t read16data(uint16_t whatbyte){
uint16_t out;
uint8_t high;
uint8_t low;
datafile.read(&high, 1);
datafile.read(&low, 1);
out = high << 8;
out += low;
return out;
void write16data(uint16_t whatbyte, uint16_t databuffer){
uint8_t high;
uint8_t low;
high = highByte(databuffer);
low = lowByte(databuffer);
datafile.write(&high, 1);
datafile.write(&low, 1);
datafile.flush();
void getdatafromfile(){
if (openspiffs()){
rowIndex = read16data(0); //read the card count from spiffs
uint16_t buffer_offset = recordlength; //start at record 1
Blynk.virtualWrite(vcount, rowIndex); // write the rowIndex to the server
for (int i = 1; i <= rowIndex; i++){ // read all the card data
// read16data(buffer_offset, tempindex); // skip the index
buffer_offset += 2;
cardHolder[i] = readstringdata(buffer_offset, maxnamelength);
cardId[i] = readstringdata(buffer_offset, maxuidlength);
accessFlags[i] = read16data(buffer_offset);
buffer_offset += 2;
yield();
closespiffs();
void dumpdatafromfile(){
String ch;
String cId;
int af;
int ri;
int tempIndex;
if ( openspiffs()){
tempIndex = read16data(0); //read the card count from fram address 0
terminal.println("index "+String(tempIndex));
for (int i = 1; i <= tempIndex; i++){ // read all the card data
ri = read16data(buffer_offset);
buffer_offset += 2;
ch = readstringdata(buffer_offset, maxnamelength);
cId = readstringdata(buffer_offset, maxuidlength);
af = read16data(buffer_offset);
buffer_offset += 2;
terminal.println("index: " + String(ri) + " holder: " + ch + " ID: " + cId + " flags: " + String(af));
yield();
terminal.flush();
closespiffs();
Wifi file
//callback notifying us of the need to save config
void saveConfigCallback () {
void restoreparameters() {
if (SPIFFS.begin()) {
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
// json.printTo(Serial);
if (json.success()) {
// json will parse the file for the variable name and load it into the supplied variable
strcpy(mqtt_server, json["mqtt_server"]); //get the mqtt_server <== you need one of these for each param
strcpy(mqtt_port, json["mqtt_port"]); //get the mqtt port
strcpy(blynk_token, json["blynk_token"]); //get the blynk token
configFile.close();
void startmywifi() {
//Local intialization. Once its done, there is no need to keep it around
WiFiManager wifiManager;
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
// The extra parameters to be configured (can be either global or just here)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
//set static ip if you want
// wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
// <============== add all your parameters here
wifiManager.addParameter(&custom_mqtt_server);
wifiManager.addParameter(&custom_mqtt_port);
wifiManager.addParameter(&custom_blynk_token);
//reset settings - for testing
// wifiManager.resetSettings(); // <========= once you have this working you can comment out this line
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
//wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
//wifiManager.setTimeout(120);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
ESP.reset(); //reset and try again
//get the custom parameters here
strcpy(mqtt_server, custom_mqtt_server.getValue());
strcpy(mqtt_port, custom_mqtt_port.getValue());
strcpy(blynk_token, custom_blynk_token.getValue());
//check the flag to see if we save the custom parameters to FS
if (shouldSaveConfig) {
JsonObject& json = jsonBuffer.createObject();
//set the custom parameters here
json["mqtt_server"] = mqtt_server;
json["mqtt_port"] = mqtt_port;
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (configFile) {
json.printTo(configFile); //write the custom parameters here
configFile.close();
} else Serial.println("failed to open config file for writing");
//end save
