OK. First I’m use external power supply (YuRobot)
and then I’m follow this step
Arduino --------------------------------------------------- ESP8266
TX0->1----------------------------------------------------> TXD
RX0->0----------------------------------------------------> RXD
GND ----------->Power Supply<----------------------- GND
3.3 V <-----------Power Supply-----------------------> VCC
3.3 V <-----------Power Supply-----------------------> CH_PD
This is the diagram for esp8266 and arduino mega 2560 wiring
This the sketch, my inspiration from here https://www.hackster.io/TomatoMan/robot-rover-iphone-controlled-using-blynk-joystick-572153?ref=part&ref_id=15659&offset=3
#include <ESP8266_Lib.h>
#include <Servo.h>
char auth[] = "TOKEN";
char ssid[] = "SSID";
char pass[] = "PASS";
#define EspSerial Serial1
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
//PIN MOTOR (USE L298N DRIVER)
int MOTOR1A = 22;
int MOTOR1B = 23;
int MOTOR2A = 24;
int MOTOR2B = 25;
int MOTOR3A = 30;
int MOTOR3B = 31;
int MOTOR4A = 32;
int MOTOR4B = 33;
int MOTOR5A = 28;
int MOTOR5B = 29;
int MOTOR6A = 26;
int MOTOR6B = 27;
//PIN MOTOR SPEED
int MOTOR1 = 7;
int MOTOR2 = 6;
int MOTOR3 = 5;
int MOTOR4 = 4;
int MOTOR5 = 3;
int MOTOR6 = 2;
//SERVO
Servo SERVO1, SERVO2, SERVO3, SERVO4, SERVO5, SERVO6;
//BLYNK
//PIN SERVO
SERVO1.attach(13);
SERVO2.attach(12);
SERVO3.attach(11);
SERVO4.attach(10);
SERVO5.attach(9);
SERVO6.attach(8);
//SERVO BEGINING
SERVO1.write(125);
SERVO2.write(40);
SERVO3.write(35);
SERVO4.write(95);
SERVO5.write(125);
SERVO6.write(85);
//MOTOR OUTPUT
pinMode(MOTOR1A, OUTPUT);
pinMode(MOTOR1B, OUTPUT);
pinMode(MOTOR2A, OUTPUT);
pinMode(MOTOR2B, OUTPUT);
pinMode(MOTOR3A, OUTPUT);
pinMode(MOTOR3B, OUTPUT);
pinMode(MOTOR4A, OUTPUT);
pinMode(MOTOR4B, OUTPUT);
pinMode(MOTOR5A, OUTPUT);
pinMode(MOTOR5B, OUTPUT);
pinMode(MOTOR6A, OUTPUT);
pinMode(MOTOR6B, OUTPUT);
//MOTOR SPEED OUTPUT
pinMode(MOTOR1, OUTPUT);
pinMode(MOTOR2, OUTPUT);
pinMode(MOTOR3, OUTPUT);
pinMode(MOTOR4, OUTPUT);
pinMode(MOTOR5, OUTPUT);
pinMode(MOTOR6, OUTPUT);
//MOTOR BEGINING
digitalWrite(MOTOR1A, LOW);
digitalWrite(MOTOR1B, LOW);
digitalWrite(MOTOR2A, LOW);
digitalWrite(MOTOR2B, LOW);
digitalWrite(MOTOR3A, LOW);
digitalWrite(MOTOR3B, LOW);
digitalWrite(MOTOR4A, LOW);
digitalWrite(MOTOR4B, LOW);
digitalWrite(MOTOR5A, LOW);
digitalWrite(MOTOR5B, LOW);
digitalWrite(MOTOR6A, LOW);
digitalWrite(MOTOR6B, LOW);
BLYNK_WRITE(V0) {
const int X_THRESHOLD_LOW = 107; //x: 127 - 20
const int X_THRESHOLD_HIGH = 147; //x: 127 + 20
const int Y_THRESHOLD_LOW = 107; //y: 127 - 20
const int Y_THRESHOLD_HIGH = 147; //y: 127 + 20
int x_position = param[0].asInt(); //Read the Blynk Joystick x Position 0-255
int y_position = param[1].asInt(); //Read the Blynk Joystick y Position 0-255
int x_direction; //Variable for Direction of Joystick Movement: x= -1, 0, 1
int y_direction; //Variable for Direction of Joystick Movement: y= -1, 0, 1
Serial.print("x_position: ");
Serial.print(x_position);
Serial.print(" y_position: ");
Serial.println(y_position);
//Determine the direction of the Joystick Movement
x_direction = 0;
y_direction = 0;
if (x_position > X_THRESHOLD_HIGH) {
x_direction = 1;
} else if (x_position < X_THRESHOLD_LOW) {
x_direction = -1;
if (y_position > Y_THRESHOLD_HIGH) {
y_direction = 1;
} else if (y_position < Y_THRESHOLD_LOW) {
y_direction = -1;
//if x and y are within the threshold their values then x_direction = 0 and y_direction = 0
//Move the Rover (Rover will move in the direction of the slower wheels)
//0,0(Stop); 0,1(Forward); 0,-1(Backward); 1,1(Right up diagonal); 1,0(Right); 1,-1(Right down diagonal);
//-1,0(Left); -1,1(Left up diagonal); -1,-1(Left down diagonal)
//x = -1 and y = -1 Back Diagonal Left
if (x_direction == -1)
if (y_direction == -1) {
Serial.print("JOYSTICK: left-down DIRECTION: BACKWARD LEFT");
Serial.print(" x_direction ");
Serial.print(x_direction);
Serial.print(" y_direction ");
Serial.println(y_direction);
SERVO1.write(90);
SERVO2.write(0);
SERVO3.write(90);
SERVO4.write(95);
SERVO5.write(180);
SERVO6.write(85);
digitalWrite(MOTOR1B, HIGH);
digitalWrite(MOTOR2B, HIGH);
digitalWrite(MOTOR3B, HIGH);
digitalWrite(MOTOR4B, HIGH);
digitalWrite(MOTOR5B, HIGH);
digitalWrite(MOTOR6B, HIGH);
analogWrite(MOTOR1,127);
analogWrite(MOTOR2,255);
analogWrite(MOTOR3,127);
analogWrite(MOTOR4,127);
analogWrite(MOTOR5,255);
analogWrite(MOTOR6,255);
//x = -1 and y = 0 Left on x axis
} else if (y_direction == 0) {
Serial.print("JOYSTICK: left DIRECTION: TURN AROUND LEFT ");
SERVO1.write(35);
SERVO2.write(130);
SERVO3.write(125);
SERVO4.write(10);
SERVO5.write(35);
SERVO6.write(170);
digitalWrite(MOTOR2A, HIGH);
digitalWrite(MOTOR5A, HIGH);
digitalWrite(MOTOR6A, HIGH);
analogWrite(MOTOR1,255);
analogWrite(MOTOR3,255);
analogWrite(MOTOR4,255);
//x = -1 and y = 1 Forward Diagonal Left
//y_direction == 1
Serial.print("JOYSTICK left-up DIRECTION: FORWARD LEFT");
SERVO1.write(180);
SERVO2.write(90);
SERVO3.write(0);
SERVO4.write(95);
SERVO5.write(90);
SERVO6.write(85);
digitalWrite(MOTOR1A, HIGH);
digitalWrite(MOTOR3A, HIGH);
digitalWrite(MOTOR4A, HIGH);
//x = 0 and y = -1 Backward
} else
if (x_direction == 0)
Serial.print("JOYSTICK down DIRECTION BACKWARD");
SERVO1.write(125);
SERVO2.write(40);
SERVO3.write(35);
SERVO4.write(95);
SERVO5.write(125);
SERVO6.write(85);
//x = 0 and y = 0 Stop
Serial.print("JOYSTICK: centered DIRECTION: STOP");
SERVO1.write(125);
SERVO2.write(40);
SERVO3.write(35);
SERVO4.write(95);
SERVO5.write(125);
SERVO6.write(85);
analogWrite(MOTOR1,0);
analogWrite(MOTOR2,0);
analogWrite(MOTOR3,0);
analogWrite(MOTOR4,0);
analogWrite(MOTOR5,0);
analogWrite(MOTOR6,0);
//x = 0 and y = 1 Forward
//y_direction == 1
Serial.print("JOYSTICK: up DIRECTION: FORWARD");
SERVO1.write(125);
SERVO2.write(40);
SERVO3.write(35);
SERVO4.write(95);
SERVO5.write(125);
SERVO6.write(85);
//x = 1 and y = -1 Backward Diagonal Right
} else
//x_direction == 1
if (y_direction == -1){
Serial.print("JOYSTICK right-down DIRECTION: BACKWARD RIGHT");
SERVO1.write(180);
SERVO2.write(90);
SERVO3.write(0);
SERVO4.write(95);
SERVO5.write(90);
SERVO6.write(85);
analogWrite(MOTOR2,127);
analogWrite(MOTOR5,127);
analogWrite(MOTOR6,127);
//x = 1 and y = 0 Right on x-axis
} else
if (y_direction == 0){
Serial.print("JOYSITCK: right DIRECTION: TURN AROUND RIGHT");
SERVO1.write(35);
SERVO2.write(130);
SERVO3.write(125);
SERVO4.write(10);
SERVO5.write(35);
SERVO6.write(170);
//x = 1 and y = 1 Forward Diagonal Right
//y_direction == 1
Serial.print("JOYSTICK: right-up DIRECTION: RIGHT");
SERVO1.write(90);
SERVO2.write(0);
SERVO3.write(90);
SERVO4.write(95);
SERVO5.write(180);
SERVO6.write(85);
This information enough? Did I miss something?
