ESP8266 Generic + ADS1115 ADC Converter
Hi blynkers,
I am trying to do really small - size iot hardware with blynk. I am using esp8266 with I2C lcd display without problems.
For analog inputs i decided to combine this board with ADS1115. But i couln’t… Here is my code, SDA connected to 0, SCL connected to 2, ADS115 address pin connected to GND. Is that possible? Sould i switch to esp32 or something else?
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads(0x48);
char auth[] = "6fb9a46b4cb84e34831d3b98b8912c78";
char ssid[] = "y-leptop";
char pass[] = "24092409";
void setup(void)
  ads.begin();
void loop(void)
  int16_t adc0;  // we read from the ADC, we have a sixteen bit integer as a result
  adc0 = ads.readADC_SingleEnded(0);
  Serial.print(adc0);
  Blynk.virtualWrite(V0, adc0);
Hi @yilmazyurdakul,
Check below link:
Thank you. This will be helpful
I properly formatted your posted code…
Blynk - FTFC
A suggestion. Keep loop simple. Just blynk.run and timer.run. Invoke all calls using timer.
