Nothing good.
I tried some basic examples, including blynk examples, everything works well.
I tried esp8266 core 2.5 and 2.61 without result.
I reinstall IDE and all libraries from scratch on an other computer too, but still same issue.
Restart your PC (it’s be helped with baud rate issues before for me)
Try a different USB port and cable
Try all different baud rates and hit the reset button on the NodeMCU until you find one where the MCU boot messages make sense, and use this baud rate for your serial print messages as well.
Load a sketch with the Erase Flash - All Flash Contents option.
Comment out any unusual libraries one at a time, along with the code that goes with them. You’ll eventually find what library it doesn’t like.
The only thing I have not tried is to load sketch with the Erase Flash All Flash Contents.
I also think a library is involved !
I 'll try one bye one !
But why an installation from scratch does not work anymore on another computer?
I changed to 9600 both, code and port, without effect
And has I said, my big home project is only impacted, all examples run with 115200 bauds without issue.
So I don’t understand , why this project run on ESP32 and not on ESP8266 since last upload.
I uploaded my previous version , but it’s still the same on the 2 NodeMCUs.
But if you’re getting some sort of hardware message on reboot you need to be at the native baud rate for the device, otherwise the message will be illegible.
Where to change this native rate?
And why can not both NodeMCUs work suddenly?
Another thing, the led does not blynk, so I’m sure the code does not work, and the Android app says nodemcu not connected.
Serial monitor rate. I’m not sure how to change it - maybe via an AT command with the original firmware, but I just set my serial baud rate to the default rate for the board i’m using so that I can set my serial monitor to the same rate and see messages from the hardware and the debug messages on the same debug screen.
When you’re connected at the correct baud rate and you do a reset you’ll see a message like this:
Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld#
If you then start getting WDT resets you’ll see a stack trace that you can copy and paste into the ESP Exception Decoder that will help you find the issue, but if your serial monitor isn’t set to the native speed of the board you’ll just get rubbish which you can’t use in the Exception Decoder.
Thank you @Lichtsignaal, I have already explored this link.
I am creating a new sketch with copy and paste, step by step, until the problem is solved.
As I have snippets , it’s not too complicated even if it’s a bit long
You might want to get a decent development platform like PlatformIO. It’ll make your life a whole lot easier. The Arduino IDE is a pain in the bum if you ask me.
