but looking at how the readme file says that it should be used…
Just replace your existing “WiFi.begin(ssid, password)” call with:
#include <AutoWifi.h>
AutoWifi a;
a.startWifi();
I don’t think its actually used in the sketch in post#25 because there is no AutoWifi object created with AutoWifi a; or equivalent and the regular WiFi.begin(ssid, pass); command is used.
I’d suggest that you comment out the #include <AutoWifi.h> line of code and see what happens.
You need to provide more information about the compiler error messages you are getting, and the steps you followed when installing the library and the error messages that you received as part of that process.
ok
`C:\Users\miale\AppData\Local\Temp\arduino_modified_sketch_488109\sketch_nov18a.ino:7:28: fatal error: OV2640Streamer.h: No such file or directory
compilation terminated.
Più di una libreria trovata per “WiFi.h”
Usata: C:\Users\miale\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Non usata: C:\Program Files (x86)\Arduino\libraries\WiFi
Più di una libreria trovata per “WebServer.h”
Usata: C:\Users\miale\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WebServer
Non usata: C:\Users\miale\OneDrive\Documenti\Arduino\libraries\Webduino-master
exit status 1
Errore durante la compilazione per la scheda AI Thinker ESP32-CAM.`
I saved the correct library imported the library from the arduino ide I compiled the program and it gives me this error
exit status 1
‘class CRtspSession’ has no member named ‘broadcastCurrentFrame’
Hi, I’m tryng to edit the sketch to control with Blynk the build-in led but it doesnt work…
Sometimes i can control the LED with blynk but the stream doesn’t work or viceversa.
If anyone is still stuck on this with an iphone, all I had to do to get it to work is to disable the use of private IP address in iPhone Wifi settings. If you are still wanting to use this, you’ll likely have to open up the subnet mask wider.
