try it this way
Certainly did try that
but it doesn’t work.
But if i use the link in my browser it works
I wrote above that the ESP 32 CAM allows only one connection. So you need to close the tab in your browser and try again on your smartphone. Sometimes, if there is no flow, Blynk has to stop and start the project again.
Yup i made sure there was nothing else connecting to it but still no luck.
I feel like the sketch i used on the ESP32 Cam is different to the sketch you used or programmed.
This is my code
#include "OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiClient.h>
#include <AutoWifi.h>
#include "SimStreamer.h"
#include "OV2640Streamer.h"
#include "OV2640.h"
#include "CRtspSession.h"
char ssid[] = ".............";
char pass[] = "..............";
// This board has slightly different GPIO bindings (and lots more RAM)
// uncomment to use
// #define USEBOARD_TTGO_T
#define USEBOARD_AITHINKER
#ifndef USEBOARD_AITHINKER
//#define ENABLE_OLED //if want use oled ,turn on thi macro
#endif
// #define SOFTAP_MODE // If you want to run our own softap turn this on
#define ENABLE_WEBSERVER
#define ENABLE_RTSPSERVER
// If your board has a GPIO which is attached to a button, uncomment the following line
// and adjust the GPIO number as needed. If that button is held down during boot the device
// will factory reset.
#define FACTORYRESET_BUTTON 32
#endif
#ifdef ENABLE_OLED
#include "SSD1306.h"
#define OLED_ADDRESS 0x3c
#ifdef USEBOARD_TTGO_T
#define I2C_SDA 21
#define I2C_SCL 22
#else
#define I2C_SDA 14
#define I2C_SCL 13
#endif
SSD1306Wire display(OLED_ADDRESS, I2C_SDA, I2C_SCL, GEOMETRY_128_32);
bool hasDisplay; // we probe for the device at runtime
#endif
OV2640 cam;
#ifdef ENABLE_WEBSERVER
WebServer server(80);
#endif
#ifdef ENABLE_RTSPSERVER
WiFiServer rtspServer(8554);
#endif
#ifdef SOFTAP_MODE
IPAddress apIP = IPAddress(192, 168, 1, 1);
#else
#endif
void handle_jpg_stream(void)
WiFiClient client = server.client();
String response = "HTTP/1.1 200 OK\r\n";
response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
server.sendContent(response);
while (1)
cam.run();
if (!client.connected())
break;
response = "--frame\r\n";
response += "Content-Type: image/jpeg\r\n\r\n";
client.write((char *)cam.getfb(), cam.getSize());
server.sendContent("\r\n");
break;
void handle_jpg(void)
cam.run();
return;
response += "Content-disposition: inline; filename=capture.jpg\r\n";
response += "Content-type: image/jpeg\r\n\r\n";
void handleNotFound()
String message = "Server is running!\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
server.send(200, "text/plain", message);
#endif
void lcdMessage(String msg)
#ifdef ENABLE_OLED
if(hasDisplay) {
display.clear();
display.drawString(128 / 2, 32 / 2, msg);
display.display();
#endif
#ifdef ENABLE_OLED
hasDisplay = display.init();
if(hasDisplay) {
display.flipScreenVertically();
display.setFont(ArialMT_Plain_16);
display.setTextAlignment(TEXT_ALIGN_CENTER);
#endif
lcdMessage("booting");
while (!Serial)
int camInit =
cam.init(esp32cam_ttgo_t_config);
#else
#ifdef USEBOARD_AITHINKER
cam.init(esp32cam_aithinker_config);
#else
cam.init(esp32cam_config);
#endif
#endif
Serial.printf("Camera init returned %d\n", camInit);
IPAddress ip;
#ifdef SOFTAP_MODE
const char *hostname = "devcam";
// WiFi.hostname(hostname); // FIXME - find out why undefined
lcdMessage("starting softAP");
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
bool result = WiFi.softAP(hostname, "12345678", 1, 0);
if (!result)
Serial.println("AP Config failed.");
return;
Serial.println("AP Config Success.");
Serial.print("AP MAC: ");
Serial.println(WiFi.softAPmacAddress());
ip = WiFi.softAPIP();
#else
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(F("."));
ip = WiFi.localIP();
Serial.println(F("WiFi connected"));
Serial.println(ip);
#endif
lcdMessage(ip.toString());
server.on("/", HTTP_GET, handle_jpg_stream);
server.on("/jpg", HTTP_GET, handle_jpg);
server.onNotFound(handleNotFound);
server.begin();
#endif
rtspServer.begin();
#endif
CStreamer *streamer;
CRtspSession *session;
WiFiClient client; // FIXME, support multiple clients
server.handleClient();
#endif
uint32_t msecPerFrame = 100;
static uint32_t lastimage = millis();
// If we have an active client connection, just service that until gone
// (FIXME - support multiple simultaneous clients)
if(session) {
session->handleRequests(0); // we don't use a timeout here,
// instead we send only if we have new enough frames
uint32_t now = millis();
if(now > lastimage + msecPerFrame || now < lastimage) { // handle clock rollover
session->broadcastCurrentFrame(now);
lastimage = now;
// check if we are overrunning our max frame rate
now = millis();
if(now > lastimage + msecPerFrame)
printf("warning exceeding max frame rate of %d ms\n", now - lastimage);
if(session->m_stopped) {
delete session;
delete streamer;
session = NULL;
streamer = NULL;
else {
client = rtspServer.accept();
if(client) {
//streamer = new SimStreamer(&client, true); // our streamer for UDP/TCP based RTP transport
streamer = new OV2640Streamer(&client, cam); // our streamer for UDP/TCP based RTP transport
session = new CRtspSession(&client, streamer); // our threads RTSP session and state
#endif
Amazing!! it worked!
Found a bug with IOS devices… it doesnt stream properly with IOS devices however on android is works 100% fine @PeteKnight
Congratulation!!!
The video streaming widget flashes the camera footage for a split second and stops buffering. However on an Android device it streams perfectly.
I know is IOS issue because i tested it on 2 IOS devices @Pavlo
This will be the first code to upload once they arrive!
Thanks for sharing.
Do you have a working public stream url you can share with me for testing?
I can do some port forwarding and PM you the address if thats fine?
If LAN can work, then install “zerotier” on the router and mobile phone to connect to the external network, no static ip is required.
I have static IP
Hello good morning, I have two ESP32Cam modules configured with the Arduino web server example and with their individual IP addresses which by entering them in the browser I can view and configure.
The problem I have is that I have been trying to configure the video settings widget in the application on my iOS mobile device for a few days by entering the IP in the url address section
http :: //XX.XX.XX.XX: 80 / but I can’t see the image of the cameras.
Has anyone got it?
I assume that’s a typo?
If I’m sorry I wrote it wrong, I wanted to put http://
Hello pouvais vous donner les librairie pour esp32-cam car je n’es pas OV2640.h
Hello Sir, i’m having a project with esp32 cam. Can you show me how to stream video with two different wifi networks: one for esp32 cam and one for my android. It means outside the LAN.
Thanks for reading.
