Hi, I have been using Blynk for only a few hours and I keep having this error when I compile:
avrdude: ser_open(): can’t open device “\.\COM3”: Access is denied.
My Arduino is an Uno and is connected through COM3. I want to use Blynk through USB because I don’t have an Ethernet Shield. I have also tried the Arduino Example Blink for an LED and that has the same error.
Please ask me if you need more info.
Thanks!
EDIT:
I FORGOT TO ADD CODE SO HERE IT IS:
#define BLYNK_PRINT SwSerial
#include <DHT.h>
char auth[] = "d2733e23ceb443d2ac964b1ad7abed56";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
SwSerial.println("Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
dht.begin();
