#define BLYNK_TEMPLATE_ID "TMPL6HUbLaRPJ"
#define BLYNK_TEMPLATE_NAME "Water Level Measurement"
#define BLYNK_AUTH_TOKEN "8_JfJQcVMIPGqcRgtHvRY3EZTkO42squ"
#define BLYNK_FIRMWARE_VERSION "1.3.2"
#include "BlynkEdgent.h"
#define echoPin 32
#define trigPin 33
long duration;
int distance;
void ultrasonic()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
distance = duration * 0.034 / 2; //formula to calculate the distance for ultrasonic sensor
Serial.print("Distance: ");
Serial.println(distance);
Blynk.virtualWrite(V0, distance);
delay(500);
pinMode(34, INPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
BlynkEdgent.begin();
delay(2000);
BlynkEdgent.run();
ultrasonic();
i use Blynk Library ver 1.3.2
Clearly you didn’t take any notice of this…
or this…
Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Then delete the screenshot of your compiler error message and replace it with the text (copied and pasted) from your IDE, and place triple backticks at the beginning and end of that too.
And, if you want help with this, tell us which version of the Blynk library you are using.
#define echoPin 32
#define trigPin 33
long duration;
int distance;
void ultrasonic()
delay(500);
pinMode(34, INPUT);
delay(2000);
BlynkEdgent.run();
ultrasonic();
extern "C" {
void app_loop();
void eraseMcuConfig();
void restartMCU();
#include "Settings.h"
#include <BlynkSimpleEsp32_SSL.h>
#ifndef BLYNK_NEW_LIBRARY
#error "Old version of Blynk library is in use. Please replace it with the new one."
#endif
#if !defined(BLYNK_TEMPLATE_ID) || !defined(BLYNK_DEVICE_NAME)
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
#endif
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
inline
void BlynkState::set(State m) {
if (state != m && m < MODE_MAX_VALUE) {
DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
state = m;
// You can put your state handling here,
// i.e. implement custom indication
void printDeviceBanner()
Blynk.printBanner();
DEBUG_PRINT("--------------------------");
DEBUG_PRINT(String("Product: ") + BLYNK_DEVICE_NAME);
DEBUG_PRINT(String("Hardware: ") + BOARD_HARDWARE_VERSION);
DEBUG_PRINT(String("Firmware: ") + BLYNK_FIRMWARE_VERSION " (build " __DATE__ " " __TIME__ ")");
if (configStore.getFlag(CONFIG_FLAG_VALID)) {
DEBUG_PRINT(String("Token: ...") + (configStore.cloudToken+28));
DEBUG_PRINT(String("Device: ") + BLYNK_INFO_DEVICE + " @ " + ESP.getCpuFreqMHz() + "MHz");
DEBUG_PRINT(String("MAC: ") + WiFi.macAddress());
DEBUG_PRINT(String("Flash: ") + ESP.getFlashChipSize() / 1024 + "K");
DEBUG_PRINT(String("ESP sdk: ") + ESP.getSdkVersion());
DEBUG_PRINT(String("Chip rev: ") + ESP.getChipRevision());
DEBUG_PRINT(String("Free mem: ") + ESP.getFreeHeap());
void runBlynkWithChecks() {
if (BlynkState::get() == MODE_RUNNING) {
if (!Blynk.connected()) {
if (WiFi.status() == WL_CONNECTED) {
BlynkState::set(MODE_CONNECTING_CLOUD);
BlynkState::set(MODE_CONNECTING_NET);
class Edgent {
public:
void begin()
indicator_init();
button_init();
config_init();
WiFi.persistent(false);
WiFi.enableSTA(true); // Needed to get MAC
printDeviceBanner();
} else if (config_load_blnkopt()) {
DEBUG_PRINT("Firmware is preprovisioned");
BlynkState::set(MODE_WAIT_CONFIG);
void run() {
app_loop();
switch (BlynkState::get()) {
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: runBlynkWithChecks(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Edgent BlynkEdgent;
void app_loop() {
Are you going to post your compiler error message text?
Hi Peter
I have the same issue.
I’m using the BlynkEdgent and the 3 mentioned lines are on the top of the code.
On the first (main) page.
The error message looks like this:
In file included from C:\Users\Sandor\Documents\Arduino\KozpontiFigyeles-OTA-08_clone\KozpontiFigyeles-OTA-08_clone.ino:40:
C:\Users\Sandor\Documents\Arduino\KozpontiFigyeles-OTA-08_clone\BlynkEdgent.h:16:2: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
16 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
exit status 1
Compilation error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
Thank You
Your triple backticks need to be immediately above and below your compiler error message, not at the beginning and end of your post. You can use the pencil icon at the bottom of the post to fix this.
Please post your sketch (with triple backticks, as explained above) and tell us which version of the Blynk library you have installed.
So instead of editing your original post and fixing the location of the triple backticks you’ve decided to post your compiler error message again!
Are you planning to provide the other information I asked for?
Edited my previous message.
Should i include anything else?
Thank You
