Dear Blynk Team
i have this error please take a look the pictures as well #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME” Blynk 2.0 i allready mention temp id and device name.
@chuonghuynh I’ve removed the code you posted because it wasn’t correctly formatted with triple backticks at the beginning and end, to make it display correctly.
Also, this isn’t the code that we need to se. We need to see the contents of your “Edgent_ESP8266.ino” file.
My guess is that you still have the #define BLYNK_TEMPLATE_ID and #define BLYNK_DEVICE_NAME lines of your code commented-out with double forward slashes (//).
Hello Everyone,
I have the same problem which jumps out after compiling the script. In the script (.ino) is all my details fill in and the line is un-commented and the problem is the same…
xxx/Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME” #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME”
Hello Everyone,
GOOD NEWS problem solved !
I was using two libraries for BLYNK…
1/ Blynk by Volodymyr Shymanskyy (v-1.2.0)
2/ BlynkESP32_BT_WF by Knoi Hoang (v-1.2.2)
Just deleted the second from Arduino IDE and problem magically disappear !
Compiled script without any issues and now in progress to upload to device.
Fingers crossed …
For anyone who is wondering why your code is not working even if you included the “BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME”, In the new update they hardcoded these variables but there seems to be a bug.
To Fix this issue [Instructions about editing the Blynk libraries removed by moderator]
Edit by moderator…
There are a number of scenarios that can cause this compiler error message in version 1.3.0 of the Blynk library…
Your #define BLYNK_TEMPLATE_ID and #define BLYNK_TEMPLATE_NAME lines of code need to be at the very top of your sketch
You need to ensure that your code does actually say #define BLYNK_TEMPLATE_ID and not #define BLYNK_DEVICE_ID
Earlier versions of the Blynk web console used #define BLYNK_DEVICE_ID and this was confusing, because the ID belongs to the template and not the device. If you created a sketch some time ago and this included #define BLYNK_DEVICE_ID then it won’t compile under release 1.3.0 of the Blynk library unless you amend this line of code.
As always, It’s recommended that you go to the web console and copy the two or three lines of firmware configuration code and paste it directly into the very beginning of your sketch.
The 1.2.0 version of the library was more forgiving about this, but the rule is once again being enforced rigidly in version 1.3.0
Your code compiles fine for me when I make this change.
I’m going to ammed your earlier post, as it’s not appropriate for users to start hacking around with the libraries to remove the enforcement of these rules.
I just checked by reverting the changes i did in the library and putting the defining variables at the top, It seems to have fixed it but a note to the devs (Nobody defines their variables before including their libraries)
I think the reason why the template ID and name need to be at the top of the sketch are so that they can be parsed correctly by the Blynk.Air process and this is why the library enforces this.
Either way, that’s the rule and Blynk requires it to be followed.
Hello pete, i already put it on the first of my sketch and it still #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME” can you help me?
