Pete,
I seem to have gotten myself in to a real mess as to where the libraries are to be located
I am no being confronted with this error message.
Please help - I am just not getting this entire thing right with one step forward and 2 steps back.
Arduino: 1.8.19 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200”
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 422816 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 29797 / 32768 - code in IRAM (IRAM_ATTR, ISRs…)
DATA : 1624 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 6124 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 27704 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 460361 bytes (44%) of program storage space. Maximum is 1044464 bytes.
Global variables use 35452 bytes (43%) of dynamic memory, leaving 46468 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM3
Connecting…
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: e8:68:e7:ce:2e:d1
Uploading stub…
Running stub…
Stub running…
Configuring flash size…
Traceback (most recent call last):
File “C:\Users\ABCD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py”, line 66, in
esptool.main(cmdline)
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 3599, in main
detect_flash_size(esp, args)
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 2848, in detect_flash_size
flash_id = esp.flash_id()
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 688, in flash_id
return self.run_spiflash_command(SPIFLASH_RDID, b"", 24)
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 948, in run_spiflash_command
old_spi_usr = self.read_reg(SPI_USR_REG)
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 562, in read_reg
val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 386, in command
p = self.read()
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 331, in read
return next(self._slip_reader)
File “C:/Users/ABCD/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
Invalid library found in C:\Data\Dropbox\Arduino\libraries\libraries: no headers files (.h) found in C:\Data\Dropbox\Arduino\libraries\libraries
“Show verbose output during compilation”
option enabled in File → Preferences.
