Can you please tell me what I am doing wrong here?
I believe I have checked that all the libraries are installed correctly and seemingly cannot find anything wrong.
Arduino IDE
#include <DHT.h>
char auth[] = "_omyDSXtrWE_7UTL3gZsurAkCaklB2zf"; //Enter the Auth code which was send by Blink
#define BLYNK_TEMPLATE_ID "TMPLwRpGCxLt"
#define BLYNK_DEVICE_NAME "NodeMCU"
char ssid[] = "Rob's Networks"; //Enter your WIFI Name
char pass[] = "4121@Flag"; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
dht.begin();
Error:
Arduino: 1.8.19 (Windows 10), Board: âNodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200â
In file included from C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/Blynk/BlynkApi.h:37,
from C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/BlynkApiArduino.h:14,
from C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/BlynkSimpleEsp8266.h:24,
from C:\Users\ABCD\AppData\Local\Temp\arduino_modified_sketch_30096\temperature-monitor-in-mobile.ino:6:
C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/Blynk/BlynkTimer.h:36:21: error: redefinition of âclass BlynkTimerâ
36 | #define SimpleTimer BlynkTimer
C:\Data\Dropbox\Arduino\libraries\SimpleTimer-1.0.0/SimpleTimer.h:10:7: note: in expansion of macro âSimpleTimerâ
10 | class SimpleTimer {
C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/Blynk/BlynkTimer.h:36:21: note: previous definition of âclass BlynkTimerâ
C:\Data\Dropbox\Arduino\libraries\Blynk-1.1.0\src/Blynk/BlynkTimer.h:43:7: note: in expansion of macro âSimpleTimerâ
43 | class SimpleTimer {
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
