BLYNK
Dynamic provisioning
I want to add a sketch to dynamic provisioning sketch.
Shall I add a tab to BLYNK --GETTING STARTED----ESP826 sketch.
I have prepared a sketch to sync manual switches with BLYNK widgets. And I want to run that sketch on dynamic provisioning.
Please help.
You need to take an example from Export_Demo, and integrate your sketch into it.
Integrate into sketch by adding a new tab.
Right?
No basically, you can just use the main ino file, which is very similar to other blynk examples :wink:
sir
kindly note my sketch is
#define VPIN1 V1  // Virtual Pins  for Blynk : Here, declared 4 virtual pins
#define VPIN2 V2
#define VPIN3 V3
#define VPIN4 V4
char auth[] = ;
char ssid[] = "Tenda_1BCB98";
char pass[] = "gagangoel";
void lightOn1();                                   // Method and variable for Relay1
void lightOff1();
boolean LampState1 = 0;
boolean SwitchReset1 = true;
void lightOn2();                                  // Method and variable for Relay2
void lightOff2();
boolean LampState2 = 0;
boolean SwitchReset2 = true;
void lightOn3();                                  // Method and variable for Relay3
void lightOff3();
boolean LampState3 = 0;
boolean SwitchReset3 = true;
void lightOn4();                                  // Method and variable for Relay4
void lightOff4();
boolean LampState4 = 0;
boolean SwitchReset4 = true;
const int TacSwitch1 = D4;                       // Connect the Tacswitch to these pins of Nodemcu
const int TacSwitch2 = D7;
const int TacSwitch3 = D6;
const int TacSwitch4 = D7;
const int Relay1 = D0;                           // Connect the input pins of Relay to these pins of Nodemcu
const int Relay2 = D1;
const int Relay3 = D2;
const int Relay4 = D3;
WidgetLED VLED1(V11);                             // Add LED in Blynk app and set its Pin as V11 (this is indication for relay1
WidgetLED VLED2(V12);                             // Add LED in Blynk app and set its Pin as V11 (this is indication for relay2
WidgetLED VLED3(V13);                             // Add LED in Blynk app and set its Pin as V11 (this is indication for relay3
WidgetLED VLED4(V14);                             // Add LED in Blynk app and set its Pin as V11 (this is indication for relay4
  pinMode(Relay1, OUTPUT);                      // Initializing relays as OUTPUT
  pinMode(Relay2, OUTPUT);
  pinMode(Relay3, OUTPUT);
  pinMode(Relay4, OUTPUT);
  pinMode(TacSwitch1, INPUT_PULLUP);           // Initializing TacSwitches as Inpull_pullup for reading the
  pinMode(TacSwitch2, INPUT_PULLUP);
  pinMode(TacSwitch3, INPUT_PULLUP);
  pinMode(TacSwitch4, INPUT_PULLUP);
  delay(20);
  digitalWrite(Relay1, HIGH);
  digitalWrite(Relay2, HIGH);
  digitalWrite(Relay3, HIGH);
  digitalWrite(Relay4, HIGH);
  Blynk.config(auth);
  timer.setInterval(100, ButtonCheck1);
  timer.setInterval(100, ButtonCheck2);
  timer.setInterval(100, ButtonCheck3);
  timer.setInterval(100, ButtonCheck4);
void ButtonCheck1() {
  boolean SwitchState1 = (digitalRead(TacSwitch1));
  if (!SwitchState1 && SwitchReset1 == true) {
    if (LampState1) {
      lightOff1();
      lightOn1();
    SwitchReset1 = false;
    delay(50);
  else if (SwitchState1) {
void ToggleRelay1() {
  LampState1 = !LampState1;
  if (LampState1) {
       lightOn1();
  else lightOff1();
void lightOn1() {
    digitalWrite(Relay1, LOW);
    LampState1 = 1;
    Blynk.virtualWrite(VPIN1, HIGH);
    VLED1.off();
void lightOff1() {
    LampState1 = 0;
    Blynk.virtualWrite(VPIN1, LOW);
    VLED1.on();
BLYNK_WRITE(VPIN1) {
  int SwitchStatus1 = param.asInt();
    if (SwitchStatus1 == 1){
    ToggleRelay1();
  else if (SwitchStatus1){
    lightOn1();
  else lightOff1();
void ButtonCheck2() {
  boolean SwitchState2 = (digitalRead(TacSwitch2));
  if (!SwitchState2 && SwitchReset2 == true) {
    if (LampState2) {
      lightOff2();
      lightOn2();
    SwitchReset2 = false;
    delay(50);
  else if (SwitchState2) {
void ToggleRelay2() {
  LampState2 = !LampState2;
  if (LampState2) {
       lightOn2();
  else lightOff2();
void lightOn2() {
    digitalWrite(Relay2, LOW);
    LampState2 = 1;
    Blynk.virtualWrite(VPIN2, HIGH);
    VLED2.off();
void lightOff2() {
    LampState2 = 0;
    Blynk.virtualWrite(VPIN2, LOW);
    VLED2.on();
BLYNK_WRITE(VPIN2) {
  int SwitchStatus2 = param.asInt();
    if (SwitchStatus2 == 1){
    ToggleRelay2();
  else if (SwitchStatus2){
    lightOn2();
  else lightOff2();
void ButtonCheck3() {
  boolean SwitchState3 = (digitalRead(TacSwitch3));
  if (!SwitchState3 && SwitchReset3 == true) {
    if (LampState3) {
      lightOff3();
      lightOn3();
    SwitchReset3 = false;
    delay(50);
  else if (SwitchState3) {
void ToggleRelay3() {
  LampState3 = !LampState3;
  if (LampState3) {
       lightOn3();
  else lightOff3();
void lightOn3() {
    digitalWrite(Relay3, LOW);
    LampState3 = 1;
    Blynk.virtualWrite(VPIN3, HIGH);
    VLED3.off();
void lightOff3() {
    LampState3 = 0;
    Blynk.virtualWrite(VPIN3, LOW);
    VLED3.on();
BLYNK_WRITE(VPIN3) {
  int SwitchStatus3 = param.asInt();
    if (SwitchStatus3 == 1){
    ToggleRelay3();
  else if (SwitchStatus3){
    lightOn3();
  else lightOff3();
void ButtonCheck4() {
  boolean SwitchState4= (digitalRead(TacSwitch4));
  if (!SwitchState4 && SwitchReset4== true) {
    if (LampState4) {
      lightOff4();
      lightOn4();
    SwitchReset4 = false;
    delay(50);
  else if (SwitchState4) {
void ToggleRelay4() {
  LampState4 = !LampState4;
  if (LampState4) {
       lightOn4();
  else lightOff4();
void lightOn4() {
    digitalWrite(Relay4, LOW);
    LampState4 = 1;
    Blynk.virtualWrite(VPIN4, HIGH);
    VLED4.off();
void lightOff4() {
    LampState4 = 0;
    Blynk.virtualWrite(VPIN4, LOW);
    VLED4.on();
BLYNK_WRITE(VPIN4) {
  int SwitchStatus4 = param.asInt();
    if (SwitchStatus4 == 1){
    ToggleRelay4();
  else if (SwitchStatus4){
    lightOn4();
  else lightOff4();
how shall I integrate with with export demo sketch which is
  This is a DEMO sketch which works with Blynk myPlant app and
  showcases how your app made with Blynk can work
  You can download free app here:
    iOS:     https://itunes.apple.com/us/app/blynk-myplant/id1163620518?mt=8
    Android: https://play.google.com/store/apps/details?id=cc.blynk.appexport.demo
  If you would like to add these features to your product,
  please contact Blynk for Businesses:
                   http://www.blynk.io/
#define USE_SPARKFUN_BLYNK_BOARD    // Uncomment the board you are using
//#define USE_NODE_MCU_BOARD        // Comment out the boards you are not using
//#define USE_WITTY_CLOUD_BOARD
//#define USE_CUSTOM_BOARD          // For all other ESP8266-based boards -
                                    // see "Custom board configuration" in Settings.h
#define APP_DEBUG        // Comment this out to disable debug prints
#include "BlynkProvisioning.h"
  delay(500);
   * Workflow to connect the device to WiFi network.
   * Here is how it works:
   * 1. At the first start hardware acts as an Access Point and
   *    broadcasts it's own WiFi.
   * 2. myPlant smartphone app connects to this Access Point
   * 3. myPlant smartphone app request new Auth Token and passes
   *    it together with user's WiFi SSID and password
   * 4. Hardware saves this information to EEPROM
   * 5. Hardware reboots and now connects to user's WiFi Network
   * 6. Hardware connects to Blynk Cloud and is ready to work with app
   * Next time the hardware reboots, it will use the same configuration
   * to connect. User can RESET the board and re-initiate provisioning
   * Explore the Settings.h for parameters
   * Read the documentation for more info: http://
  BlynkProvisioning.begin();
  example_init(); // Initialize this example
  // This handles the network and cloud connection
  BlynkProvisioning.run();
  // Run this example periodic actions
  example_run();
 *              myPlant example App code
 * The following code simulates plant watering system
BlynkTimer timer; // Initiating timer to perform repeating event
static int sensorSoilMoisture = 60;
static int sensorAirHumidity = 50;
static int wateringAmount = 5;
static int wateringTimer = -1;
static bool isNotificationSent = false;
// Getting data from "Set watering amount" slider
BLYNK_WRITE(V5) {
  wateringAmount = param.asInt();
  DEBUG_PRINT(String("Watering amount: ") + wateringAmount);
// Getting data from "Start Watering" button
BLYNK_WRITE(V6) {
  if (param.asInt() == 1) {
    // If watering started -> start simulating watering
    timer.enable(wateringTimer);
    DEBUG_PRINT("Watering started by user");
    // If watering stopped -> stop simulating watering
    timer.disable(wateringTimer);
    DEBUG_PRINT("Watering stopped by user");
// When device starts ->
//   sync watering switch button status
//   and watering amount level from the cloud (last App value)
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V5, V6);
// This is a sinusoidal function used for simulations
float sinusoidal(float minv, float maxv, float period) {
  float amp = (maxv - minv) / 2.0;
  float med = minv + amp;
  return med + amp * sin((M_PI * 2 * millis()) / period);
// Simulating values jittering
float randomize(float minv, float maxv) {
  return float(random(minv * 1000, maxv * 1000)) / 1000;
void example_init() {
  // Update sensors each 3 seconds
  timer.setInterval(3000L, []() {
    // Soil moisture
    if (sensorSoilMoisture < 33) {
      Blynk.virtualWrite(V1, "DRY");
    } else if (sensorSoilMoisture > 33) {
      Blynk.virtualWrite(V1, "MOIST");
      Blynk.virtualWrite(V1, "WET");
    float dayPeriod = 3.0 * 60 * 1000;
    // Light level
    int light = sinusoidal(5, 95, dayPeriod);
    if (light < 33) {
      Blynk.virtualWrite(V2, "LOW");
    } else if (light > 33) {
      Blynk.virtualWrite(V2, "GOOD");
      Blynk.virtualWrite(V2, "MED");
    // Temperature
    Blynk.virtualWrite(V3, sinusoidal(18, 23, dayPeriod) + randomize(-1.0, 1.0));
  // Humidity updates at a different rate (5s)
  timer.setInterval(5000L, []() {
    sensorAirHumidity += random (-5, +5);
    sensorAirHumidity = constrain(sensorAirHumidity, 30, 90);
    Blynk.virtualWrite(V4, sensorAirHumidity);
  // Soil Moisture decreases 3% every second
  timer.setInterval(1000L, []() {
    sensorSoilMoisture -= 3;
    sensorSoilMoisture = constrain(sensorSoilMoisture, 7, 85);
    if (sensorSoilMoisture < 20) {
      if (isNotificationSent == false) {
        Blynk.email("myPlant notification", "Your plant is thirsty!");
        isNotificationSent = true;
        DEBUG_PRINT("Email notification sent");
  // Simulate watering process
  wateringTimer = timer.setInterval(1000L, []() {
    sensorSoilMoisture += wateringAmount;
    if (sensorSoilMoisture > 30) {
    if (sensorSoilMoisture >= 85) {
      // Stop watering
      // Update "Start Watering" button widget state
      Blynk.virtualWrite(V6, 0);
      DEBUG_PRINT("Watering stopped automatically");
void example_run() {
@gagansite Please kindly note the proper procedure to post code in this the forum… I have already fixed you last post.
As for your question, that entirely depends on your level of coding experience… not something we can teach here.
