Hi all,
I’m lost with a very simple script: retrieving data from a DS18B20.
I spent last 3 hrs aroud it… no solution.
- Script is quite basic, in terms of errors everythink is fine (no mistake by Arduino IDE)
- In terms of data I can see from serial monitor data coming right (so in terms of wiring and connection everything is fine)
- I see the node mcu on line
but… my “Labelled Value” box still 0.00 where I’m wrong? It’s connected to V1
Here my code:
#include <OneWire.h>
OneWire oneWire(D2); // digital D2 pin
char auth[] = "f9c1ZZZZZZZ4cb";
char ssid[] = "YYY";
char pass[] = "XXX";
float temp = 0;
sensors.begin();
timer.setInterval(1000L, sendTemps);
void sendTemps()
temp = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V1, temp);
Serial.print("Temperature for the device is: ");
Serial.println(sensors.getTempCByIndex(0));
Here a print screen where I got numbers in serial monitor:
What happens if you change this line:
to this?:
Serial.println(temp);
The reason for the question is that your sendTemps() function is taking a temperature reading and saving the result to the variable temp. You’re then sending this value to Blynk. Rather than also sending the same value to the serial monitor, you’re taking a new reading and sending it to the serial monitor.
It could be that the the first time a temperature reading is taken is a little soon after the sensors.requestTemperatures(); command, but the second time the reading is taken it returns a result. Making the change shown above will prove or disprove this theory, but at least we’ll then know that EXACTLY the same data is being sent to both Blynk and the serial monitor.
what do you see if you replace by
oooops
you are faster than me. @PeteKnight
Hi, thank you for your fast answers
Ok, it made this chance
Here updated code:
char auth[] = "XXXXXXX";
char pass[] = "ZZZ";
float temp = 0;
sensors.begin();
void sendTemps()
in the code but result still the same;
I see numbers in serial monitor but it still 0.00 in the Blynk App
Here the setting on App:
Ok
try float temp instead of float___ temp without =0 and no more space between float and temp
float temp;
instead of
Hi Blynk_Coeur,
I edit the file without luck
The UI still showing 0.00
here code:
char auth[] = "XXX";
char ssid[] = "YY";
char pass[] = "ZZ";
float temp;
sensors.begin();
void sendTemps()
I really don’t understand
Just to confirm, you’ve uploaded the new code to your NodeMCU and it uploaded correctly without any errors?
The reason for asking is that I’ve wasted time before thinking that I was running updated code when it was still using the old version of the code because the upload failed and I hadn’t noticed
Hi PeteKnight,
doublechecked. It shows 100%…
One more, just to confirm. You have the App running? That is, you have pressed the play button on the upper right hand corner?
Hi Toro_Blanco,
to avoid any confusion I killed the app (IOS) and restarted.
That said I always check the connection status; when the code is uploaded I usually lose the nodemcu for few second (new code is uploaded).
@Toro_Blanco the serial monitor print zero too …
@Blynk_Coeur, I was under the impression it was only BLYNK that was not displaying the dtat.
Hi Blynk_Coeur,
here what I see in the serial monitor (the right temperature)
so if you see
that is to say “temp” is ok
so there is probably a problem with the widget
Hi Blynk, yes the problem is 100% on the widget / virtual write.
I tried also generating a new Labeled Diplay - Value Display - Gauge… result still the same…
Can we see the full output from the serial monitor, from boot-up please?
Select it in the serial monitor using CTRL A and copy using CTRL C then paste it into the forum with triple back-ticks at the beginning and end.
Hi Pete, is it ok?
Temperature for the device is: 23.81
Temperature for the device is: 23.87
