Placing the simple code for network access has the following error:
Meu código abaixo:
http://twitter.com/blynk_app
This example shows how LOW/HIGH event may be triggered from
Blynk Server to Arduino at specific time.
Timer widget works for ANALOG and DIGITAL pins also.
In this case you don't need to write code.
Blynk handles that for you.
App project setup:
Timer widget attached to V5 and running project.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "*************************";
char ssid[] = "LoVeS";
char pass[] = "******";
BLYNK_WRITE(V5)
// You'll get HIGH/1 at startTime and LOW/0 at stopTime.
// this method will be triggered every day
// until you remove widget or stop project or
// clean stop/start fields of widget
Serial.print("Got a value: ");
Serial.println(param.asStr());
