Please Help, Im trying to connect DHT11 with a Moisture sensor the code up loads DH11 shows the reading on the gauge but the moisture sensor doesnt show anything on the gauge when placed into a cup of water, this is my code
#include <DHT.h>
char auth[] = "*************"; //Auth code
char ssid[] = "********"; //WIFI Name
char pass[] = "***********"; //WIFI Password
#define DHTPIN 2 // Digital pin 4
#define soilPin 0
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity(); // in %
float t = dht.readTemperature(); // in C
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
void sendsoilSensor()
float s = analogRead(soilPin);
if (isnan(s)) {
Serial.println("Failed to read from Gas sensor!");
return;
Blynk.virtualWrite(V7, s);
dht.begin();
