Keeping it simple since I’m just toying with IoT, regardless of how I change the lines the temperature remains `C.
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(true); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature```
I have tried every combination and Googled myself silly. Know it is simple but my weakness in coding complicates matters.
//Temperature sensor
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how value can be pushed from Arduino to
* the Blynk App.
* WARNING :
* For this example you'll need SimpleTimer library:
* https://github.com/jfturcot/SimpleTimer
* and Adafruit DHT sensor library:
* https://github.com/adafruit/DHT-sensor-library
* App project setup:
* Value Display widget attached to V5
* Value Display widget attached to V6
#include <DHT.h>
char auth[] = " "; //Enter the Auth code which was send by Blink
char ssid[] = " "; //Enter your WIFI Name
char pass[] = " "; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4
void sendSensor()
return;
dht.begin();
The first time I fired up the DHT 11 with a nano and 16-2 lcd I remember having to add the conversion formula, maybe being 72 yrs old that part of my memory has gotten corrupt so I will go back and start from scratch.
Just used the “Blynk Sketch Builder” and still the same results!
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
App project setup:
#include <DHT.h>
char auth[] = "";
char ssid[] = "Ubiquiti";
char pass[] = "";
#define DHTPIN 2 // What digital pin we're connected to
void sendSensor()
return;
dht.begin();
