come in Europe, you don’t need F°
The thing is that the code names the DHT library, but it doesn’t include the library.
When the code compiles it uses the library you have installed on your PC. If you have multiple versions of the library installed it will pick one of them, which may not be the one you expect.
Turn on verbose compiler messages in the IDE and look at the last few messages. It will tell you which library is used, and if come were ignored.
Thank you Pete, I will after thr race…
Think I have bigger problems then code, getting errors loading and I know the library folder is in the correct location and has worked before.
Putting this beg on hold until all is normal!
And I thank everyone for all the positive input in this matter.
Think you need to replace the space with an underscore for that library.
DHT Library > DHT_Library
That was it, Thanks.
EUREKA!
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "64119237de3f4bea803fdd3e0c8d5434";
char ssid[] = "Ubiquiti";
char pass[] = "YorkiePoo2007";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.print((int)round(1.8*t+32));
Serial.println(" *F");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
