I am trying to add a device on an Android, using the Blynk IOT app.
I have loaded the example Edgent ESP8266 code to my Wemos D1 Mini pro successfully.
When i try and connect to the device i am able to find and connect to the blynk network however on attempting to connect to the household wifi I always get
“You device couldn’t connect to the network”
I am at a complete loss as to why something so simple is just not working.
Okay, that’s not the problem then.
Very long template ID’s produce even linger SSIDs which exceed what the ESP8266 can handle when creating the access point for provisioning.
Are you running a 2.4 GHz WiFi network that you’re connecting your ESP to?
I notice that you haven’t un-commented a board type…
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
//#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
which means that the default board type will be used.
It probably also means that the LED and provisioning reset button probably aren’t working. Is this correct?
Even though the App doesn’t connect to the network. When i look at my router I can see an “Blynk-LED-Blink-360D5” wireless client as a connected item.
On the Blynk website I have created the template. I am not attempting to add a device to that template on my phone via the app.
I have loaded the code in the pastebin above onto the wemos d1 mini pro sucessfully. When trying to add a device I get all the way until the configuring device section and then it fails. Here is the serial monitor output
