Hello this function working fine; but i dont want to repeat the same CLI status every 30000 msec .
How to avoid; this is token is from thermostat , and is sending status v72 (0) or (1) bi every 30 sec, is conected to esp8266.
I use the same token123456 1 from esp8266 1 from rasppi to bridge .
i have Error and the script from rasp pi is closing.
I want to change the status once or twice off CLI.
Note if i put another v pin for example v9 is working fine from the button app.
On mi console appear v72 0
v72 0
v72 0
v72 0
v72 0
until is change the status off v72
v72 1
v72 1
v72 1 etc
rasp pi
var Blynk = require('blynk-library');
var AUTH = '123456';
var blynk = new Blynk.Blynk(AUTH);
var process = require('child_process');
var v72 = new blynk.VirtualPin(72);
var v2 = new blynk.VirtualPin(2);
v72.on('write', function(param) {
console.log('V72:', param[0]);
if (param == 0) {
blynk.virtualWrite(2, 0);
process.exec('node /home/pi/my-awesome-project/indexoff.js', function (msg) { console.log(msg) });
} else if (param == 1) {
blynk.virtualWrite(2, 255);
process.exec('node /home/pi/my-awesome-project/indexon.js', function (msg) { console.log(msg) });
esp8266
#include <DHT.h>
#define DHTPIN 12
#define DHTTYPE DHT22
char auth[] = "123456";
char ssid[] = "xxx";
char pass[] = "xxxx";
const int red = 0;
const int green = 1;
const int blue = 16;
const int pbuttonPin = 5; // change as per your button attached.
const int relayPin = 14;
const int rel = 2;
int motorInitiated = 0;
int motorInitiated1 = 0;
int motorInitiated2 = 0;
int motorInitiated3 = 0;
int motorInitiated4 = 0;
int motorInitiated5 = 0;
int motorInitiated6 = 0;
int motorInitiated7 = 0;
int setTemp;
int t1;
int val = 0; // push value from pin 2
int lightON = 0;//light status
int pushed = 0;//push status
DHT dht(DHTPIN, DHTTYPE);
WidgetBridge bridge1(V1);
BLYNK_CONNECTED() {
Blynk.syncAll();
// Place the AuthToken of the second hardware here
bridge1.setAuthToken("56e9098a1b5c43f5a5e230055b186c75");
BLYNK_WRITE(V11) {
int pinData = param.asInt();
if (pinData == 1) {
digitalWrite(blue, HIGH );
motorInitiated = 0;
timer.restartTimer(t1);
timer.disable(t1);
motorInitiated++;
motorInitiated1++;
motorInitiated2++;
digitalWrite(red, HIGH);
digitalWrite(green, HIGH );
BLYNK_WRITE(V71) {
if (pinData == 1) {
motorInitiated7++;// Sets motor Initiated to 1
BLYNK_WRITE(V3)
setTemp = param.asInt();
void sendSensor()
float h = dht.readHumidity();
Blynk.virtualWrite(V41, h);
Blynk.virtualWrite(V31, t);
if (isnan(h) || isnan(t)) {
return;
if (t >= setTemp)
timer.disable(t1);
motorInitiated1++;
motorInitiated2++;
if (motorInitiated == 0) {
digitalWrite(green, LOW );
else {
digitalWrite(red, LOW );
motorInitiated6++;
timer.enable(t1);
else {
motorInitiated1++;
motorInitiated2++;
digitalWrite(blue, LOW );
void sendSensor1() {
if (motorInitiated1 == 0)
void sendSensor2() {
if (motorInitiated2 == 0)
delay(500);
delay(500);
delay(500);
void sendSensor3()
val = digitalRead(pbuttonPin);// read the push button value
if (val == 1 && lightON == 0) {
pushed = 1 - pushed;
delay(200);
lightON = val;
if (pushed == 1 && motorInitiated3 == 0) {
motorInitiated4++;
else {
if (motorInitiated4 == 0 && motorInitiated5 == 1)
digitalWrite(relayPin, HIGH);
digitalWrite(relayPin, LOW);
void sendSensor4() {
if (motorInitiated6 == 0 && motorInitiated7 == 0)
digitalWrite(rel, HIGH);
bridge1.virtualWrite(V72, 0);
digitalWrite(rel, LOW );
bridge1.virtualWrite(V72, 1);
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(pbuttonPin, INPUT_PULLUP);
pinMode(relayPin, OUTPUT);
pinMode(rel, OUTPUT);
digitalWrite(green, HIGH);
digitalWrite(blue, HIGH);
dht.begin();
timer.setInterval(800L, sendSensor);
timer.setInterval(400L, sendSensor2);
timer.setInterval(300L, sendSensor3);
timer.setInterval(35000L, sendSensor4);
t1 = timer.setInterval(3600000L, sendSensor1);
timer.disable(t1);
the arduino code is running fine , i dont want to change.
