Datastream Fahrenheit Units Issues
Maybe I just don’t know how to use it. First time Blynk user here.
TLDR; ESP8266 with a MAX6675 sensor. Temp reporting fine with a V0 and V1 pins. But when I define the Units on the datastream to be Fahrenheit it converts to C…which makes no sense… the code is sending the value in F.
 Blynk.virtualWrite(V0, ktc.readCelsius());
 Blynk.virtualWrite(V1, ktc.readFahrenheit());
Maybe I’m missing the point how this works? Thanks for the help.
Defining the unit during the data stream setup will only display the unit. It doesn’t convert or do any math.
There must be something wrong in your code or data stream mismatch.
See to that you are sending correct data to the proper data stream.
Thanks for the quick reply. I been breaking my head. The same call ktc.readFahrenheit() reports correctly if I remove the unit on the datastream. I’m attaching a screenshot of the datastreams definition. Like I said. first time using Blynk.
What widget are you using to display the data?
Gauge…
Is your serial monitor showing the correct values?
Post your serial monitor output properly formatted with triple backticks( ``` ) at the beginning and ending of the output.
Also try deleting the data stream and try creating again.
Yep both the Serial and the OLED connected are displaying right… just the Blynk…
18:29:34.271 -> C = 22.75	 F = 72.95
18:29:34.271 -> C = 23.00	 F = 73.40
18:29:35.201 -> C = 22.75	 F = 72.95
18:29:36.297 -> C = 22.50	 F = 72.50
18:29:37.390 -> C = 22.50	 F = 72.50
Trying to recreate the Datastream now. :slight_smile:
Update: Nope… no joy… still reporting weird… :frowning:
Heres even more weird… On the Template preview it shows the Unit as F… but when I look at the device it shows C… whaaaaaa… Attaching screenshots.
Template Edit
Device view (sorry new user can only post one photo per post)
I’d suggest that you start by posting your FULL sketch.
Yep thats a fair callout. Here it is.
#include <Blynk.h>
#include <max6675.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define BLYNK_TEMPLATE_ID "XXXX"
#define BLYNK_TEMPLATE_NAME "XXXX"
#define BLYNK_AUTH_TOKEN "XXXX"
#define SCREEN_WIDTH 128    // OLED display width, in pixels
#define SCREEN_HEIGHT 64    // OLED display height, in pixels
#define OLED_RESET -1       // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
char auth[] = "XXXX";    // You should get Auth Token in the Blynk App.
char ssid[] = "XXXX";                       // Your WiFi credentials.
char pass[] = "XXXX";
int ktcSO = 12;
int ktcCS = 13;
int ktcCLK = 14;
MAX6675 ktc(ktcCLK, ktcCS, ktcSO);
  Serial.println("Max6675 test");
  display.begin(SSD1306_SWITCHCAPVCC, 0x3c); //initialize with the I2C addr 0x3C (128x64)
  delay(500);
  display.clearDisplay();
  display.setCursor(25, 15);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.println(" Thermometer");
  display.setCursor(25, 35);
  display.print("Initializing");
  display.display();
  delay(3000);
  float DC = ktc.readCelsius();
  // Read temperature as Celsius
  float DF = ktc.readFahrenheit();
  Serial.print("C = ");
  Serial.print(ktc.readCelsius());
  Serial.print("\t F = ");
  Serial.println(ktc.readFahrenheit());
  display.setCursor(20, 0);
  display.print("Temperature");
  display.setTextSize(2);
  display.setCursor(10, 20);
  display.print(ktc.readCelsius());
  display.print((char)247);
  display.print("C");
  display.setCursor(10, 45);
  display.print(ktc.readFahrenheit());
  display.print("F");
  display.display();
Vovovovovo
Your loop is a complete mess.
Read this
Https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
As @Madhukesh said, your void loop is a mess.
You are also taking readings and storing them in the variables DC and DF, but then you aren’t using these variables again. Instead, you’re repeatedly taking new readings. This is the wrong approach.
When you move all of this junk out of your void loop and into a function that’s called with a BlynkTimer (and of course delete the delay command) you should structure the function so that you take readings at the beginning of this function and store them in variables, then use these variables when you send the values to the serial monitor, LCD and Blynk.
Thats good feedback from both you. I’ll have a closer look and adjust. Thanks
Well… I’m no expert but I tried to follow your advice and based on the great post you did Using BlynkTimer or SimpleTimer and this is the current status…
#include <Blynk.h>
#include <Wire.h>
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
char auth[] = "";    // You should get Auth Token in the Blynk App.
char ssid[] = "";                       // Your WiFi credentials.
char pass[] = "";
int ktcSO = 12;
int ktcCS = 13;
int ktcCLK = 14;
// This function creates the timer object. It's part of Blynk library
void getTemp()
  Blynk.virtualWrite(V0, DC);
  Blynk.virtualWrite(V1, DF);
  Serial.print(DC);
  Serial.println(DF);
  display.print(DC);
  display.print("C");
  display.print(DF);
  display.print("F");
  display.display();
  timer.setInterval(5000L, getTemp);
  delay(500);
  display.display();
  delay(3000);
  timer.run(); // call the BlynkTimer object
  Blynk.run(); // perform a handshake with the Blynk server
And unfortunately I’m still getting the same results. I’m attaching a side by side photo of the lcd and the blynk on the phone. This photo is with No Units defined on the Datastream V1. It shows the right value… I tried with setInterval 1sec and 5sec. Same result.
PS: The code does look cleaner, thanks for the tip.
What happens if you setup the data stream with units?
It seems to use the C value but looks funny on the bottom… Same has before… see screenshots.
will attach datastream definition to other reply…
What do you see if you add two gauges to the web dashboard (and I’m not interested in the template preview screen, it means nothing)?
Also, if your desired range is 0°C to 600°F then the min/max for your Fahrenheit datastream should be 32 to 1112
I’ve corrected the datastream Min and Max and heres a screenshot of the web dashboard. Shows the exact same issue as the iOS App version.
