not very relaible. i mean not realtime.
as i said, create a sketch containing nothing else just sending the uptime every second.
if you can see that increments somewhat regulalry on phone, for several minutes, that i call a good connection.
The email have been coming. But, itās so long to come.
please try this:
and report back what it does.
edit: i assume you are on uno + usb serial internet
if not, correct it accordingly,
I have make the code as you said:
#define BLYNK_PRINT SwSerial
char auth[] = "******************************************";
int buzzer = 13 ;// define buzzer Interface
int pin = 2; // define the flame sensor interface
int analoog = A0; // define the flame sensor interface
int val ;// define numeric variables val
float sensor; //read analoog value
void myTimerEvent()
sensor = analogRead(analoog);
Serial.println(sensor); // display temperature
val = digitalRead (pin) ;// digital interface will be assigned a value of 3 to read val
if (val == HIGH) // When the flame sensor detects a signal, buzzer beep
digitalWrite (buzzer, HIGH);
digitalWrite (buzzer, LOW);
pinMode (buzzer, OUTPUT) ;// define buzzer as output interface
pinMode (pin, INPUT) ;// output interface defines the flame sensor
pinMode (analoog, INPUT) ;// output interface defines the flame sensor
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
Nothing happened after I upload the sketch. So, what should I do so that the app can be realtime?
As it states in the sketch⦠this example sends data to the App on V5⦠so create a Display Widget on Virtual Pin 5 and set itās reading frequency to PUSH (that means it waits until data is PUSHED to it from the Server). Then once your MCU and App are properly connected through the server you will see the seconds add up on the display.
This is an example of how timers can be used in Blynk instead of āmanuallyā counting millis() or using delay()
I have set the input to V5 and reading frequency to PUSH. But, still nothing value appear on my app. What causes the appās is not real-time?
I donāt know, it could be many things.
Have you ever had a basic Blynk example sketch successfully functioning?
Like the one @wanek suggested and I was refering too⦠NOT one where you have tried to merge in your other fire sensor code⦠just the basic Blynk example sketchā¦
Yes, I have tried that and nothing value appear. But, the app just online if I connect to internet and the email coming on my push notif code. Is it because I use usb serial?
OK, lets focus on that sketch by itself then, no email, no fire sensor⦠just load up that example and create a simple project with a single display widget in it, set to V5 and PUSH. Make sure you have the same authcode from that project loaded in the sketch.
You are using an UNO with USB link correct? Do you have a 2nd USB-TTL adapter to use with the software serial for monitoring data on the IDE monitor?
No, I donāt have that USB-TTL.
Too bad⦠it would make your diagnostics easier.
Well, just load up that simple sketch and widget and let me know if it works or not.
By the way, which usb-ttl should I use? Cause I still never use it. Beside, usb-ttl pl2303 and rs232 have same pins.
They all work the same way, but driver support for your PC is probably the most important.
On the USB-TTL there will be Power, and Ground⦠this is usually to supply 5v power from the USB the board you are connecting to⦠and both can be ignored (donāt plug them into anything) in this case, as your Arduino is already getting power from itās own USB connector.
The TX (usually green) & RX (usually white) connect to correspondingly opposite RX & TX pins on the Arduino, determined by the software serial setup. This is a simple RS232 connection.
Then I use a program called Termite - Termite: a simple RS232 terminal to display the data from that USB-TTL adapter. In most Blynk example cases, that data is the diagnostic info coming from the Blynk sketch on the Arduino.
Try to avoid the PL2303 if you are using a fairly modern Windows machine. There are a lot of fake chips around and Prolific drivers donāt seem to work with Windows 7 and on beyond even for genuine chips.
They can be made to work by using a driver from 2003 but Windows keeps insisting you should use the latest, broken, driver. For me it involves a lot of driver removal and PC reboots to get them to work. You canāt simply plug and unplug them or Windows will give you the broken drivers.
Ahh, thatās probably what I am running into then⦠I have to manually direct it to a Pyramid driver, then all works until next reboot⦠but since my PC runs 24/7, that is a rare issue (and now that I have ESP, even rarer needed
but you can buy one decent version with 0.6 euro:
Best quality 1Pcs USB to TTL converter UART CH340G CH340 3.3V 5V switch replace of CP2102 PL2303 module
http://s.aliexpress.com/eeY3emmI
(from AliExpress Android)
@wanek yes the CH340ās are fine. Might get hold of some but I have 20+ PL2303ās to use up.
The PL2303ās are OK if you just want to power up an ESP / MCU rather than actually flash it
I have try upload push data code with CH340, and the value has been appeared. Is it indicate the connection has been real time?
I also try upload my push notif sketch with CH340. Nothing email coming. Instead, if I just use usb serial, the email coming. But, I have to wait some minutes.
@Maria please provide your sketch that fails i.e the one with CH340.
Do you have Serial Monitor wired up and can you paste the data from it?
Here is my code:
char auth[] = "********************************************";
void readSensor() // Costas
// long uptime = millis() / 60000L; Costas
//delay(1000); // Costas
// Notify immediately on startup
if(val==HIGH){
//Blynk.notify("Flame!!!");
Blynk.email("nurlela.dabukke@gmail.com", "Flame!!!", "Sensor activated");
// Setup a function to be called every 200ms Costas
timer.setInterval(10L, readSensor); // Costas
But, everytime the flame went out, always there are comment in the app āthe device is offlineā. If I click serial monitor, the port always busy.
I think, itāll better if I use wemos d1 mini.
