I have remake the circuit, but I still don’t know if it’s correct or not.
I also remake the sketch, please let me know if I’m wrong.
#include <Wire.h>
#inlclude <Adafruit_ADS1015.h>
#define LDR A1
#define PIR1 D5
#define LED1 D8
#define PIR2 D3
#define LED2 D4
char auth[] = "f40e7c2f2e3245258332dbc89c7e9e78";
char ssid[] = "Redmi 3s";
char pass[] = "69AEE473";
Adafruit_ADS1115 ads(0x48); /* Use this for the 16-bit version */
//Adafruit_ADS1015 ads; /* Use thi for the 12-bit version */
int pirState1; // define numeric variables val for PIR1
//int ldrValue;
int pirState2 = 0;// define numeric variables val for PIR2
//int buzzer = D1 ;// define buzzer Interface
int flame = D0; // define the flame sensor interface
//int analoog = A0; // define the flame sensor interface
int val ;// define numeric variables val
//float sensor; //read analoog value
bool isFirstConnect = true;
void readSensor1()
int16_t adc0;
adc0 = ads.readADC_SingleEnded(0);
//ldrValue = analogRead(LDR);
if (adc0 <= 270) { // dark
digitalWrite(LED1, HIGH);
else {
pirState1 = digitalRead(PIR1);
if (pirState1 == HIGH) {
digitalWrite(LED1, LOW);
else { // pirState1 == LOW
void readSensor2()
pirState2 = digitalRead(PIR2);
digitalWrite(LED2,pirState2);
if (pirState2 == 1)
digitalWrite(LED2,LOW);
void readSensor3()
int16_t adc1;
adc1 = ads.readADC_SingleEnded(1);
//sensor = analogRead(analoog);
Serial.println(adc1);
//Serial.println(sensor); // display temperature
//long uptime = millis() / 60000L;
Blynk.virtualWrite(V1, millis() / 1000);
val = digitalRead (flame) ;// digital interface will be assigned a value of 3 to read val
if (val == HIGH) // When the flame sensor detects a signal, buzzer beep
//digitalWrite (buzzer, HIGH);
Blynk.email("nurlela.dabukke@gmail.com", "Flame!!!", "Sensor activated");
//else
// digitalWrite (buzzer, LOW);
// Actually send the message.
// Note:
// We allow 1 notification per 15 seconds for now.
//Blynk.notify(String("Running for ") + uptime + " minutes.");
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
pinMode(LED1, OUTPUT);
pinMode(PIR1, INPUT);
pinMode (LED2,OUTPUT);
pinMode (PIR2, INPUT);
//pinMode (buzzer, OUTPUT) ;// define buzzer as output interface
pinMode (flame, INPUT) ;// output interface defines the flame sensor
//pinMode (analoog, INPUT) ;// output interface defines the flame sensor
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
// Notify immediately on startup
Blynk.notify("Device started");
if(val==HIGH){
//Blynk.notify("Flame!!!");
//Blynk.email("nurlela.dabukke@gmail.com", "Flame!!!", "Sensor activated");
// Setup a function to be called every minute
timer.setInterval(10L, readSensor3);
// Setup a function to be called every 200ms Costas
timer.setInterval(150L, readSensor3); // Costas
//timer.setInterval(350L, readSensor3);
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
// ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
ads.begin();
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("ADS1115 STARTING!!!!");
isFirstConnect = false;
if (Blynk.connected()) {
