Create Push Notification over Flame Sensor
So how to fix the error?
Disconnect the WeMos and then plug it back in. espcomm is a common issue and certainly the Mini’s will upload at 921600 speed 90% of the time.
Ok, I’ll try it.
I have try it again, and the error become more and more.
    error: failed sending 0xC0
    error: failed sending 8 bytes
    error: failed sending 36 bytes
    warning: espcomm_sync failed
    error: espcomm_open failed
    error: espcomm_upload_mem failed
How to test the WeMos board? I still never test it yet.
Is it the full or mini D1?
Have you installed the drivers?
Which com port is it connected to?
Test with Standalone sketch.
Yes, I have installed driver CH341SER, library esp8266, and phyton 3.6.2. I use full WeMos and I use Arduino 1.6.11. The port is COM10.
But, where is that standalone sketch?
Is it esp8266_standalone?
yes that’s right.
Do you have REAL WeMos or ā€œfakeā€ i.e. was it bought from WeMos (real) or elsewhere (fake)?
I have tried esp8266_standalone. There are still error like that.
I think it’s fake. What is the difference between the original and the fake anyway?
Some fakes don’t work.
Most do but you now need to ask on WeMos forum, even though you didn’t purchase from them.
If you sort out the espcomm and still have problems with Blynk please post again.
Do you have recommendations for which shield should I use? I think, it’ll better if I buy the new shield. I want to look for shield which there are many in market.
Take a look at this https://www.aliexpress.com/store/product/WEMOS-D1-mini-Pro-16M-bytes-external-antenna-connector-ESP8266-WIFI-Internet-of-Things-development-board/1331105_32724692514.html and their website for the mini at https://wiki.wemos.cc/products:d1:d1_mini_pro
  1. update the arduino ide to current version. 1.6 is obsolete!
  2. afaik, you have to install python 2 not 3.
  3. make sure you have a good quality data cable, not longer than 0.5m (not some cheapo charging cable)
  4. if the above 2 points are valid, and still no luck, try reducing the baud rate to lower speed (512000)
@wanek, I have followed your instructions. But, the error still there.
@Costas, here is my WeMos shield.
What do you think? It’s original or clone?
Dunno, hard to tell.
See espcomm error discussion on GitHub at Fatal exception (28) Ā· Issue #280 Ā· esp8266/Arduino Ā· GitHub
@Costas, I think I’ll just use USB serial because my deadline has been very close. After I upload the sketch, still nothing notif appear but the buzzer rang. I also have reduced the interval up to 10, but still nothing notif.
Another college project?
Just to be clear on Notify:
Android is OK, iOS doesn’t have it yet.
You need the Notification widget in your project and best set to PRIORITY of HIGH.
Notify isn’t a good widget for testing purposes. Serial Monitor access, using a USB2TTL adaptor if necessary, is essential until you know what you are doing.
Got lot’s of limitations and if I was your College lecturer I would dock you 50% just for thinking about it :slight_smile:
Paste your sketch and someone might take a look at it.
Yes, this project deadline has been very close. I have to submit this project draft to my campus as my final project tomorrow. This is just for temporary. I still will attempt to use WeMos for the connection. But, if the WeMos still being error, then I have no other choice beside USB serial.[quote=ā€œCostas, post:40, topic:15891ā€]
[/quote]
Please don’t like that. I just have no choice, I’m so hopeless because I have try many way but still no luck. By the way, I’m so thank full for you @Costas and @wanek to help me to finish my final project. I wish, this project can be success.[quote=ā€œCostas, post:40, topic:15891ā€]
[/quote]
I think, I need a USBTTL adaptor. I have set the PRIORITY to HIGH. But, still nothing notif.
Anyway, what should I do with USBTTL? Because, I have never used it :grinning:
