Controling switch-buton by using arduino?
Hi
im using a switch-button on blynk dashboard to control a relay for 30min
how can i realize that the switch-button falls back after 30min? (when the relay is low again)
By using the button’s On status to trigger a timeout timer that runs for 30 minutes, then writes an Off value to the widget’s virtual pin.
You might want to read these…
You can also try the automation which is the easiest way, you can use the automation to make something like this
