I am trying to integrate nodemcu with Blynk app. In the app I have configured node mcu and trying tp connect. Serial monitor show the ip address. router is recording ip address.
I have tested Node mcu with example code and its working fine. Same thing if i do client application it will work.Currently i dont have internet connectivity ,just connecting to wifi and posted my authorization code.
It will popup window something went wrong .error msg shown below
My testing code.Here i have not posted my authorization code simply posted last digit
If you donât use a local server but try to connect to the server on the internet without being connected to the internet it will not work - no surprise
weather software blynk wont work on local server. without internet connection.
i have tested device using local server with same ip 192.168.1.2 its working . if i use blynk library and connected to common router local web server must work right.
Without internet connectivity how can i test nodemcu unit using local server??
@Blynk_Coeur: No need for a gateway if you donât want to go to the internet. Server, App and nodemcu are in the same IP subnet. The minimum needed is a PC/Laptop and a small ârouterâ that has Wifi.
Iâve tested a setup like this with a small 3G access point with no SIM card in it - i.e. not internet connection.
In its config I only had to allow the connected device to communicate internally.
I am testing same method. I have already tested dht11 and other with nodemcu using local Web server using client app. But I canât able to connect using blynk app. I donât have Internet connection but just using laptop nodemcu WiFi router. And connected locally
Currently I am trying simple evirtual led using
Blynk software. I have configured like shown in example. Only there is no where mention about Internet connectivity. So I am facing this issue. Like I share you tube video I need to test it out.
I have tested nodemcu with local server without Internet using client application. But I canât able to connect locally using blynk.
Itâs entirely possible to run local server without an Internet connection. In fact, you can do it without a router, wireless access point etc if you wish. See this topic:
@ajitnayak87 if you want others to help you with your problem then your communication needs to be much clearer and more detailed. You need to explain your network architecture in detail, and show how youâve set-up your app, including which port youâve chosen in your app configuration.
Blynk consists of three parts, The App, the Server and the MCU (Arduino, ESP, RPi (as client), etc.) that runs the Blynk Library & script. All three must communicate together, via a network.
APP â network/internet â SERVER (Cloud or Local) â network/Internet â MCU
If the server used is the default Cloud Server, then that requires the internet. However you can install a Local Server on a PC or Linux device like a Raspberry Pi (as server), and then run everything on an internal network.
Just did a test with local server running on my Windows PC. App and ESP-01 connected to a LAN/Wifi router with the PC in the same IP subnet. Working 100% without problem.
On thing to consider:
For this test I simply start the server with
java -jar server-0.39.1.jar -dataFolder ./Blynk
Without using port forwarding on the server PC from port 80 to port 8080 or changes in the server.config
the IP port 8080 needs to be explicitly defined in Blynk.begin() as shown in the corresponding examples.
This does NOT work as the default port 80 is used:
Sorry for my English. I may not communicate properly here .
I have Nodemcu Hardware -> Wifi router which are all connected to same network . I have blynk app connected to same network .
i would like to create a local server where i could develop APP that can communicate via app locally .
Local Webserver that can be used to view data locally . I am thinking of using Nodered for local web communication later use port forwarding
These plan to execute my project @ first level. Since i am new to this how can i go ahead here.
1)which Platfrom used to create own dashboard with local server
2) How can i create my own local server without connect internet. I tried following link . But facing issue while installation
If you canât even get the local Blynk server setup to run without an internet connection then I think youâre being far too ambitious with your overall project.
Personally, I donât see why you need a dashboard in addition to Blynk.
