I wanted to connect my esp8266 (Nodemcu using Arduino IDE) to Multiple available Access points using Blynk . Searched for it and came across this. It has exactly what i need that is connecting to multi-wifi using blynk ,but the problem is the Iāve kept 2 of SSIDās as hidden and 1 as visible. The tutorial mentioned can connect to non-hidden SSIDās easliy but doesnāt work with hidden SSIDās.Iāve tried giving overload function WiFi.scanNetworks(async, show_hidden) like the one mentioned in this doc https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/scan-class.html but still it doesnāt connect .it always loops in a wifi search . tried commenting on that tutorial but never got any solutions for it.All i want is that the esp8266 gets connected to the SSID which has the best signal,incase if anyone of them fails.also a bit confused on using Wifi.begin() for using Multi-wifi library when iām using Blynk.begin().
Itāll be very helpful if somebody can show me how it can be achieved.
Also this is my first Post here,kindly bear with me.
Itās good that youāve done some research before posting. You can sharpen the most powerful tool in learning (searching, researching) by using the correct search topics. For example in this forum you can see MultiWiFi MultiBlynk topics:
and many many more discussing similar things.
RE: Hidden WiFi SSID, there are many limitations as you canāt scan and show hidden SSID (thatās the main purpose). You have to know exactly the hidden SSID/PW to input.
Sorry for the late reply . Thank you for the insight. I went through the two above mentioned links and found out that both do not meet the requirements. The second one only works for ESP32 !!
Btw,I exactly know my SSID/PW (hidden)
My only requirement is that it should connect to any one of the hidden SSIDās that iāve pre-configured in sketch,not passing it through some GUI ,as it is for remote home automation .
Could anyone please Help me find the solution to this
If you want to connect to the hidden SSID with the best signal strength then youāll need to connect to them in turn and check the RSSI readings. If the one you are currently connected to is better than the first one you tried then continue with that, otherwise disconnect and re-connect to the first one.
Personally, Iād give both hidden networks the same SSID and password and just connect to it. The ESP will take care of connecting to the strongest access point.
#ifndef ESP32
#error This code is intended to run on the ESP32 platform! Please check your Tools->Board setting.
#endif
Iāve tried that too, but unfortunately Iām ending up in a network loop (maybe my router doesnāt allow multiple access points with the same name, I know ideally it shouldnāt happen but thatās what Iāve observed). Thatās why i had to give different names to my access points but now i donāt have redundancy if any access point breaks down. Forget connecting to the best signal strength ,i just want it to connect it to any available SSID that Iāve preconfigured in the sketch.
Yes, in the ESP32 examples. But if you look at the ESP8266 examples youāll see:
Sorry very neglectful of me
Is your second access point set-up as a DCHP server?
Initially upon first encountering the issue , I found out that indeed it was ,but upon removing the DHCP function from the one of the access points still Iām face Network Loop issue If i have the same SSID/pw for all my access points.Went on a google spree trying to find a solution for it but couldnāt find a thing for my particular setup, so ended up giving different credentials to the access points and now have no redundancy
Thereās quite a few topics on hard-coding multiple SSIDs, maybe this is the simplest to run withā¦
Iāll try this with my test setup and see if it works (particularly with hidden SSID)
I guess it depends on the type of WAP. I have 4 wired WAPs in addition to my router, all using the same SSID and password, to provide total coverage for the house and garden.
Wireless repeater WAPs tend to be more difficult to configure to work on a single SSID, although some of the Netgear Nighthawk routers do allow āsingle SSIDā usage, but Iām not sure if this applies to hidden SSIDs.
Ok , I tried this on my test sketch and Iām happy to report that this indeed works, with hidden SSIDās too !!
My only gripe is this
while (!Blynk.connected() && ssid_count<ssid_mas_size);
if (!Blynk.connected() && ssid_count==ssid_mas_size) {
Serial.println("I could not connect to blynk =( Ignore and move on. but still I will try to connect to wi-fi " + String(ssid[ssid_count-1]));
with this,even if it doesnāt connect to Blynk Servers it stays connected to that Access point (āIgnore and move on. but still I will try to connect to wi-fiā) . Somewhat defeating the whole purpose of redundancy (Connect to the access point that has internet connectivity or else try the next one ).Any ideas for this ?
You could use Blynk.connected to see if you are connected to Blynk:
If not, then do a wifi disconnect and re-connect to the other SSID.
Or, you could ping a website (the Blynk server or google.com maybe) to see if you are connected to the internet and if not then switch to your alternate WiFi connection.
As I said, the code I linked to was a starting point for you to run with.
Running a basic home automation setup with ep8266(nodemcu),referring to my post regarding connecting to multiple ssids in case of a WiFi failure, came across this post , been running this for a while now and facing a issue where the esp8266 still is connected to the internet but looses connection to blynk server(as it still continues to get the time from ntp meaning the internet is still connected). The code runs fine for a day or two and all of a sudden goes offline for almost an entire day,is this because of a possible flood error(& yes my void loop() is clean AF with just Blynk.run(); timer.run(); ) How to determine if anything is causing a flood error? I am sending around 20 values(mostly weather stuff) via blynk every 5 seconds or so. Btw, i have a timer for resetting the esp twice a day and sometimes even after resetting blynk doesnāt get connected but it gets the time via ntp rather fine . Is something wrong in the connecting to blynk process in this code? is checking Blynk.connected(); every minute a bad practice?
Little snippet of my code:
pinMode(D0,OUTPUT);
pinMode(D1,OUTPUT);
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
pinMode(D5,OUTPUT);
pinMode(D7,OUTPUT);
pinMode(D8,OUTPUT);
digitalWrite(D0,LOW);
digitalWrite(D1,LOW);
digitalWrite(D2,LOW);
digitalWrite(D3,LOW);
digitalWrite(D4,LOW);
digitalWrite(D5,LOW);
digitalWrite(D7,LOW);
digitalWrite(D8,LOW);
WiFi.softAPdisconnect (true);
wifi_set_sleep_type(NONE_SLEEP_T);
MultyWiFiBlynkBegin();
Blynk.syncAll();
dht.begin();
terminal.println(F("------terminal-------"));
terminal.flush();
timer5 = timer.setInterval(60000L, MultyWiFiBlynkBegin);
Serial.println();
Serial.print("Connecting to the Internet ");
Serial.println();
Serial.print("Connecting Now...");
Serial.println();
Serial.println("Successfully Connected to the Internet ");
Serial.print("NodeMCU IP Address : ");
Serial.println(WiFi.localIP() );
Serial.println("Channel : " + String(WiFi.channel()));
configTime(timezone, dst, "pool.ntp.org","time.nist.gov");
Serial.println("\nWaiting for Internet Time");
while(!time(nullptr)){
Serial.print("*");
Serial.println("\nSyncing Time Now...");
void MultyWiFiBlynkBegin() {
int ssid_count=0;
int ssid_mas_size = sizeof(ssid) / sizeof(ssid[0]);
do {
if (!Blynk.connected()) {
digitalWrite(D8,LOW);// power to router
Serial.print("\n" );
Serial.println("Trying to connect to WiFi " + String(ssid[ssid_count]));
WiFi.begin(ssid[ssid_count], pass[ssid_count]);
int WiFi_timeout_count=0;
while ((WiFi.status() != WL_CONNECTED) && (WiFi_timeout_count<50)) { //waiting 10 sec
delay(200);
Serial.print(".");
++WiFi_timeout_count;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Connected to WiFi! WiFi SSID = "+ String(ssid[ssid_count])+"!");
Serial.println("Checking connection to Blynk server");
Blynk.config(auth);
Blynk.connect(); //for waiting 5 sec Blynk.connect(5000);
varssid=ssid[ssid_count];
int quality = getQuality();
++ssid_count;
Serial.print("\n\n" );
Serial.println("Could not connect to Blynk =( Retrying!! Please Wait .....");
Iāve moved this post to your original topic, as itās really just a continuation of the same subject.
More accurately, I provided you a link to that post and suggested that it could be a good starring point.
Code snippets are useful in some cases, but in this case I donāt think that the code youāve provided helps anyone to assist you with resolving your issue(s).
No, not based on the snippet of code youāve provided (but as that isnāt the complete picture then its impossible to know if youāre doing āillegalā elsewhere).
Could these be causing more then 10 virtual writes per second? - if so then thatās āillegalā
While loops are blocking and canāt be exited until the criteria are met. They donāt seem to be an appropriate method in this case, but its difficult to understand the code flow based on this snippet blah, blah, blahā¦
