I’m having a problem. I can get my arduino UNO R3 to connect via USB. However, when I touch a button on my android phone, the arduino deconnects from my phone and I get this message from the CMD.
Connecting device at COM3 to blynk-cloud.com:8442...
OpenC0C("\\.\COM3", baud=9600, data=8, parity=no, stop=1) - OK
Connect("blynk-cloud.com", "8442") - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
Here is my code. It seems to be my code the issue. I doesn’t disconnect when using exemples.
// #define BLYNK_PRINT SwSerial
char auth[] = "token";
BLYNK_WRITE(V1)
calibration=param.asInt();
if (calibration==HIGH) {
calibrer();
BLYNK_WRITE(V2)
int bouton = param.asInt(); // assigning incoming value from pin V1 to a variable
//Bouton pour redémarrer le calcul de la moyenne sans reset et passer par la calibration a nouveau
if (bouton==HIGH) {
totalaverage=0;
numaverage=0;
void calibrer()
digitalWrite(ledPin, HIGH);
debutcalib=millis();
// Laisser le capteur à une différence de pression nulle pendant 5 secondes
while ((fincalib-debutcalib) <= temps_calibration) {
i++;
sensorValue = analogRead(sensorPin);
total=total+sensorValue;
fincalib=millis();
calibration=total/i;
// signal the end of the calibration period
digitalWrite(ledPin, LOW);
SwSerial.begin(9600);
pinMode(ledPin, OUTPUT);
Blynk.begin(Serial, auth);
calibrer();
numaverage++;
readIndex=1;
total=0;
debutlecture=micros();
while ((finlecture-debutlecture) <= 1000000) { //Valeurs moyenné au 1 sec pour le serveur blynk
debut=micros();
//Lecture du sensor
sensorValue = analogRead(sensorPin); //Setup le sensor à 0 pression, une valeur de 0. Si delta_pression<0 alors valeur négative
Delta_pression=(sensorValue-calibration)*maxsensor*2000/1024; //, transformation de la valeur analogue en pression Pa
// Serial.print(Delta_pression);
total=total+Delta_pression;
readIndex++;
finlecture=micros();
// Valeur graphique échantillons numReadings
PressionSmooth=total/readIndex;
Blynk.virtualWrite(V6, Delta_pression);
//Valeur moyenne depuis départ
totalaverage=PressionSmooth+totalaverage;
average=totalaverage/numaverage;
Blynk.virtualWrite(V5,average);
//Fréquence d'échantillonage
frequence=1000000/(finlecture-debut); //Calcul de la fréquence d'échantillonage
vitessemax=frequence*60/5; //Vitesse maximale du moteur en RPM pour une belle lecture
Blynk.virtualWrite(V3,frequence); //Pour une lecture facile sur le plot
You are doing to much in your void loop(), including a delay() (which stops ALL processing for that timeframe) and all that will interrupt Blynk causing the disconnections.
Look through this and other Help Documents to see how to use timers, etc.
The thing is, I need my sensor to run at a high frequency, at least 100 Hz. I can’t wait for each call of the function (which I read has to be at least 1 seconde) to make my readings and I want my readings to be as continuous as possible.
Is there a way to make it work without the loop?
I put the delay to be sure not to overload the server. I’ll delete it.
Well thanks for the tip! I think I found a good work around
Could you just take a look?
Is it a good way to have a continuous reading (averaged for every time the print is called)?
Thanks!
//Declarer les fonction de Blynk
BlynkTimer freq;
BlynkTimer moyen;
BlynkTimer lecture;
char auth[] = "auth";
BLYNK_WRITE(V1)
calibrer();
BLYNK_WRITE(V2)
if (bouton==HIGH) {
totalaverage=0;
numaverage=0;
void calibrer()
i++;
fincalib=millis();
void mean()
void frequency()
frequence=1000000/(fin-debut); //Calcul de la fréquence d'échantillonage
void lec()
// On reset les valeurs pour la prochaine lecture
readIndex=1;
total=0;
//Timer pour pas overload serveur
freq.setInterval(1000L, mean);
moyen.setInterval(1000L, frequency);
lecture.setInterval(100L, lec);
//Calibration du sensor
calibrer();
debut=micros();
//Lecture du senso
readIndex++;
fin=micros();
lecture.run();
numaverage++;
moyen.run();
freq.run();
Yes, a Local Server will greatly increase throughput… providing your local network is good. But you you can still have disconnection issues or some lag, as WiFi is still a bottleneck… but much better then a full Internet link.
Adding this line may also help with Local Server, at least with Blynk data transmission… no benefit for actual sensor readings as that is mostly the device and code… not sure it is as effective on the Cloud though.
