sketch_mar13a:21: error: 'param' was not declared in this scope
int V= param.asInt(V1);
C:\Users\LOGIC ONE\Documents\Arduino\sketch_mar13a\sketch_mar13a.ino: In function 'void BlynkWidgetWrite1()':
sketch_mar13a:68: error: 'pinvalue1' was not declared in this scope
myservo.write(pinvalue1);
Multiple libraries were found for "Servo.h"
Used: C:\Users\LOGIC ONE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0\libraries\Servo
Not used: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
#include <Servo.h>
Servo myservo;
int rfright = 14 ;
int rfmid = 12;
int rfleft = 13;
char auth[] = "a7436918884f406492d4be5e74023032";
char ssid[] = "*******";
char pass[] = "******";
int right= digitalRead(rfright);
int left=digitalRead(rfleft);
int mid= digitalRead(rfmid);
pinMode(rfleft, INPUT);
pinMode(rfmid, INPUT);
pinMode(rfright, INPUT);
myservo.attach(15);
BLYNK_WRITE(V1) // Run this function when V1 button pressed.
int pinValue = param.asInt(); // Get status of V1.
if (pinValue == 1)
{ // If status of V1 is 1 then do stuff in if().
void BlynkWidgetWrite1();
if (pinValue == 0)
if(right == LOW)
myservo.write(120);
delay(50);
if(left == LOW)
myservo.write(30);
delay(50);
if (mid == LOW)
myservo.write(80);
delay(50);
int pinValue1 = V;
